To answer Nobby’s question, there are several 12BA screws in my skeleton clock. They hold the hardened end (thrust) plates in position for the bottom bearing of the balance wheel arbor, and the bottom bearings of the two escapement arbors.
Having said that, and this is about tapping and the use of tap wrenches, I have to admit that under these circumstances, I twirled the taps in and out between my finger and thumb.
AND, I was only tapping into brass.
It’s nearly forty years ago so I can’t remember exactly, but I may have assessed the resisting torque versus the tap’s strength together with the squeak coming from the brass/tap, to know when to back off.
If we are talking about screw size, my ego is quickly deflated when I peer inside an old watch.
Sam
