Is Abwood English or American
Home Forums Workshop Tools and Tooling Is Abwood English or American
  • #133081
    Graham Wharton
      @grahamwharton
      Just trying to work out whether the threads on an old Abwood 4inch milling vice are likely to be UNC or BSW.
      Its got 1/4, 5/16 and 3/8 threads on it, but UNC and BSW are the same pitch.
      I've tried winding in both UNC and BSW bolts, and I cant tell any difference.
      On one hand I'm thinking why bother getting it right if both fit, but then again my nut and bolt OCD will be off the scale if I don't use the right ones.
      TIA
      Graham
      Graham Wharton
        @grahamwharton
        #133083
        S.D.L.
          @s-d-l
          Posted by Graham Wharton on 19/10/2013 18:14:49:
          TIA
          Graham
          A wood is / was British but if from 60s could be either as unified threads were adopted me tween whit worth and metric. My Colchester student Mkll is UNC.
          steve
          #133088
          Muzzer
            @muzzer
            Doesn't sound as if it's critical either way but the UNC has 60 degrees and Whit is 55 degrees so arguably a thread gauge and a magnifying glass might give you the answer. Pity it doesn't have a 1/2" thread as that would give the game away definitively. My milling machine (Taiwanese BP clone) has Whit, UNC and Metric all together, all original. You got away lightly!
            Merry
            #133107
            Martin Walsh 1
              @martinwalsh1
              Abwood are still going strong
              http://www.abwoodcnc.co.uk
              Best Wishes Martin
              Edited By Martin Walsh 1 on 19/10/2013 21:47:34
              #133153
              Lambton
                @lambton
                Graham,
                Despite the difference in thread angle UNC and BSW (other than 1/2" are interchangeable. This is why the UNC is called Unified. It was to do with standardising screw threads between England ,Canada and the USA in 1949 to avoid some of the problems encountered during WW2. The Unified system did not last too long in this country mostly applied to motor vehicles and agricultural equipment in the 1960s and 1970s.
                The unified system produces rather inelegant fastenings with A/F head sizes that are not a fixed proportion of the thread diameter as in Whitworth thread. Strangely no attempt was made to "unify" BSF thread with the ANF series.
                Fortunately metrication put a stop to the use of unified threads in this country many years ago.
                Eric
                Edited By Lambton on 20/10/2013 11:10:21
