Posted by Chris TickTock on 25/07/2020 15:15:11:
Posted by John Haine on 25/07/2020 14:24:08:
I use an airbrush compressor to blow chips away from the tool on my small CNC mill. You need to have the mill in a box or chips will go everywhere. Won't work if you are using coolant. As CNC cuts can be rather long I added an ex- computer fan on to the end of the casing to keep the motor cool.
Thanks John, your so right a little box will be made to keep the chips from going astray….
Chris
Be careful with a little box as a catcher because it's easy to bounce muck straight back into your eyes. Also be careful not to blow swarf into your workshop's delicate little places. It can do a lot of damage to ways, motors, and electronics.
Air-cooling and mist systems may be best avoided because they're hazardous compared with drips, brushes and floods. Although they're a 'good thing' the pros tend to keep them fully enclosed so the operator can't get a face or lung full. I feel they're over the top in a small workshop.
Nothing special in my workshop. I cut steel and Brass dry with Carbide and brush Aluminium with WD40 or paraffin. Threads and parting off are both lubricated with CT90. Steel being cut with HSS gets a heavy oil, Lawnmower Oil at the moment, but I've used basic Engine Oil, and 3-in-1. Way Oil seems to work well, as does neat Cutting Oil (for making Suds). I brush swarf away rather than blow it.
A Sherline being a gentlemanly machine rather than a crude bruiser probably doesn't need more than a generous brush-full or dribble now and again as work progresses. If using carbide, don't splash the insert directly. ( Allegedly, thermal shock can crack them, though it's not happened to me yet!)
My biggest single waste of money so far is the Flood Cooling System I fitted to my Mill. Works perfectly well, except it's only needed once in a Blue Moon for protracted deep cuts in steel, which I do rarely. Most of my work doesn't involve lots of metal munching. I drill holes and tidy edges rather than convert anvils into engine blocks!
