Is a bath sponge suitable as temporary fix for car air filter?
Home Forums The Tea Room Is a bath sponge suitable as temporary fix for car air filter?
Viewing 25 posts - 1 through 25 (of 32 total)
  • #630023
    Simon Robinson 4
      @simonrobinson4
      After the heavy rain last week I gave my diesel car a check over and discovered rain water had got into my paper air filter and it had fallen apart. There’s a leak at the top of the bonnet and rain water seeps into the air filter box. Thankfully no water got into engine and it turns over as normal.
      Is a dry bath sponge suitable to replace the filter with so I can drive out and buy a new air filter?
      Simon Robinson 4
        @simonrobinson4
        #630024
        lee webster
          @leewebster72680
          I have three Austin Sevens, none of them have air filters or were ever fitted with filters. You might notice a difference in performance because the engine will be getting more air. Why not phone a local garage or automotive supplier and ask if will do the car any harm to drive to them? Good luck.
          #630027
          john halfpenny
            @johnhalfpenny52803
            Air filters are hardly necessary in the UK. One of my vintage cars has done 25K miles in my care without one.
            #630028
            john halfpenny
              @johnhalfpenny52803
              #630029
              Paul Rhodes
                @paulrhodes20292
                I will third what John says!
                #630031
                Nicholas Farr
                  @nicholasfarr14254
                  Hi, if you have a Turbocharger, I understand that it is very unwise to run it without a proper air filter.
                  Regards Nick.
                  #630033
                  Clive Brown 1
                    @clivebrown1
                    For a short trip, I'd go without a filter. Diesels have a strong suck, you might end up with a sponge in one of the cylinders.
                    #630034
                    Nigel Graham 2
                      @nigelgraham2
                      That's not a very answerable question because you'd need think of the volume of air the individual sponge can pass at its expected flow-rate. Too porous and it might have implications for a turbo as Nicholas warns; insufficiently porous and you'd probably be running the engine too rich and lowering its power..
                      I suspect bath-sponges come in as many porosities as shapes and sizes, and I doubt the cashier in Poundland or Boots would be able to advise you on this.
                      #630035
                      duncan webster 1
                        @duncanwebster1
                        Order one on line it will come very quickly, might get tomorrow if you pay a bit more.
                        #630044
                        Mike Poole
                          @mikepoole82104
                          If getting wet continues to be a risk then maybe K&N do a non paper element filter for that application. I would be more worried about a hydraulic lock but sucking a soggy filter into the engine is not to be recommended, If it got stuck on an exhaust valve seat it could soon wreck the valve.
                          Mike.
                          #630046
                          Baz
                            @baz89810
                            Totally agree with Duncan, get on line and order yourself one, you will most probably get it before the weekend.
                            #630047
                            V8Eng
                              @v8eng
                              Deleted V8
                              Edited By V8Eng on 18/01/2023 16:51:38
                              #630059
                              Jeff Dayman
                                @jeffdayman43397
                                Don't play around with air filters. Get the right one and get it in. Any engine is extremely costly to repair or replace these days, not smart for OP to risk one on an air filter substitute. (or for any other filter, for that matter)
                                Edited By Jeff Dayman on 18/01/2023 17:59:52
                                #630070
                                Dave Halford
                                  @davehalford22513
                                  Modern engines may refuse to run if the air supply does not fall with in the specs. Limp mode isn't fun.
                                  Your real problem is that the water will probably do it again. Are you sure it hasn't got there from a big water splash?
                                  A lot of modern cars have a very low air inlet behind the bumper.
                                  #630074
                                  Samsaranda
                                    @samsaranda
                                    I wouldn’t use a sponge in place of the proper air filter it will inevitably be sucked into the engine, proper air filters have reinforcements that prevent this happening. A drive to the dealers to get a replacement wouldn’t hurt the engine, it would only be potentially harmful if you decided to run without permanently. Dave W
                                    #630084
                                    Martin Kyte
                                      @martinkyte99762
                                      Well it will certainly mop up the water that gets into your engine space.
                                      regards Martin
                                      #630086
                                      Chris Mate
                                        @chrismate31303
                                        A sponge filter should have a wire mesh/metal perforated plate(small holes) to rest against to prevent it from being sucked in, if its restricted I think you going to have a lazy diesel engine as oppose to an enriched(choked) petrol engine with a carburettor.
                                        #630088
                                        Hopper
                                          @hopper
                                          What on earth kind of car do you have that a) Lets so much water in around the bonnet b) Allows so much water to enter the air-filter housing and c) Has such a junky filter element that it disintegrates on contact with water, which is a common component of intake air? Lada? Trabant? Other?
                                          The rest of us would like to be forewarned to avoid that brand and model, whatever it is.
                                          #630089
                                          noel shelley
                                            @noelshelley55608
                                            DO NOT DO IT ! run without, I dont know where you are but you can use my trade account if you have an MPD branch near you. Noel.
                                            #630091
                                            Jon Lawes
                                              @jonlawes51698
                                              Is the car french by any chance? Seemingly a french design technique is to put the air inlet low to the ground for cold air, I've noticed it more on my french cars than other brands.
                                              #630092
                                              Samsaranda
                                                @samsaranda
                                                A few years ago my neighbour had a Renault and he drove through some floodwater and the engine stopped. It had ingested a considerable amount of water because the air intake was so low down in the engine compartment, the engine was totally wrecked, I believe the water caused hydraulicaling in the cylinders and the engine was not repairable. Dave W
                                                #630115
                                                Simon Robinson 4
                                                  @simonrobinson4
                                                  Posted by Jon Lawes on 18/01/2023 21:38:21:
                                                  No it’s a 2007 Fiat Panda diesel. They put a bolt hole just above the filter box in the window drain Channel and rain water leaks through this hole and drips into the filter box soaking the air filter. I’ve put some grease over the bolt temporarily but will clean it up with cellulose thinners and use silicon seal to stop the rain getting through.
                                                  #630116
                                                  Simon Robinson 4
                                                    @simonrobinson4
                                                    Posted by Hopper on 18/01/2023 21:16:19:
                                                    It’s a 2007 Fiat Panda diesel. It’s a design fault. They put a bolt hole just above the filter box in the window drain Channel and rain water leaks through this hole and drips into the filter box soaking the air filter. Fortunately the filter box has a hole in the bottom so it doesn’t flood with rather but it seems this drain was retro fitted as manufactures knew it was a problem.
                                                    #630118
                                                      Posted by Simon Robinson 4 on 19/01/2023 08:12:56:
                                                      Looks like one of the easiest filter-changes possible; **LINK**
                                                      Shame some idiot designer spoiled the ship for the proverbial ha’porth of tar crying 2
