Involute gear cutters?
Home Forums Workshop Tools and Tooling Involute gear cutters?
  • #551008
    Bo’sun
      @bosun58570
      Good afternoon,
      I need to buy a DP involute gear cutter/cutters to make two gear wheels. Am I correct in assuming I need to select it depending on how many teeth each gear has?
      Bo’sun
        @bosun58570
        Buying the right one(s)?
        #551009
        not done it yet
          @notdoneityet
          Yes, and the correct DP and pressure angle. Likely more than one if tooth counts differ by just a few.
          #551013
          geoff walker 1
            @geoffwalker1
            I think they're numbered 1 to 8
            Number 1 cutters for a large number of teeth down to number 8 which cuts gears with 13  teeth.
            Some years ago I bought 3 cutters numbers 6,7 and 8 to cut 3 gears 20t, 16t and 13t. all cutters around 25 quid each from rdg in halifax.
            The cutters were great, still using them now
            Geoff
            Edited By geoff walker 1 on 23/06/2021 13:24:33
            Edited By geoff walker 1 on 23/06/2021 13:25:20
            #551016
            Howard Lewis
              @howardlewis46836
              If do not already have a copy, it might be worth getting Ivan Law's book "Gears and Gear Cutting" No 17 in the Workshop Practice Series.
              The formulae in it are invaluable.
              As warned, you need to ensure that the cutter is for the correct DP AND Pressure Angle.
              Cutters are numbered 1 to 8
              No 1 – 135T to Rack, No.2 – 55T -134T, No.3 – 35T – 54T, No.4 – 26T – 34T, No.5 – 21T – 25T, No.6 – 17T – 20t, No.7- 14T – 16T, No.8 – 12T and 13T.
              It may be that cutters for Module gears are numbered in reverse order. Anyone to confirm?
              Module is the Metric equivalent to DP
              HTH
              #551021
              Anonymous
                Posted by Howard Lewis on 23/06/2021 14:26:59:
                Correct, annoyingly module cutters are numbered in reverse.
                #551051
                ega
                  @ega
                  I seem to recall someone who bought a set of module cutters which *were* numbered as for DP.
                  Plus one for Ivan Law.
                  #551056
                  not done it yet
                    @notdoneityet
                    The range for the cutters is that the cutter is sized for either maximum or minimum of its range (can’t remember which). That means that the odd tooth (or maybe two) difference will make no odds if the tooth counts are top of one range and bottom of the next one up – ie no point in getting two adjacent numbered cutters if one gear is only a tooth outside of range. Thought and common sense needed to be applied in these marginal instances.
                    #551064
                    Anonymous
                      Posted by not done it yet on 23/06/2021 18:28:40:
                      ….the cutter is sized for either maximum or minimum of its range (can’t remember which).
                      An involute cutter has the correct tooth form for the lowest number in its range.
                      #551115
                      Chris Crew
                        @chriscrew66644
                        I have bought several involute cutters from RDG and found them to be very satisfactory. I would not hesitate in ordering some more when required. I have cut gears and racks using the 'Myford' method, with the dividing head mounted on the vertical slide and now mostly on an horizontal mill with a Vertex BS 0 dividing head. Both methods worked for me and the gears and racks mesh and perform their intended function. How precise they are I have no idea but as an amateur pottering around in a back-shed workshop I don't have to submit to any inspection process. I can also highly recommend Ivan Law's book.
                        Edited By Chris Crew on 24/06/2021 08:26:11
                        #551124
                        Bo’sun
                          @bosun58570
                          Thanks all for the confirmation.
