Inverter wiring diagram
Home Forums Help and Assistance! (Offered or Wanted) Inverter wiring diagram
  • #748544
    john fletcher 1
      @johnfletcher1
      Has a reader got a fitting /wiring  instruction manual or sheet for an old RS inverter, part number 266 – 8856, if they have I would appreciate a copy This inverter no longer stock by RS, and the part number has been given to another component. A friend has a 2007 catalogue and it was listed then, but no longer available. I have contacted RS. John
      Robert Atkinson 2
        @robertatkinson2
        The term “inverter” covers a multitude of items. Do you have any more details?
        Unfortunatly RS are very protective of their IP so the internet archive is not much help. The early 21st centuary is also when RS started playing with CD-ROM based catalogs. some of these have data but the CDs run RS software and you can only have one installed at a time. I might have somethine but it means digging out a disk, getting out an old WinXP pc and doing an installation before I can even look 🙁
        Robert.
        #748588
        Andrew Tinsley
          @andrewtinsley63637
          I should think a good photo or two of the inverter would narrow down the inverter to a specific manufacturer. With a bit of luck even the model could be surmised. Then a search can be made for the instructions.
          Andrew.
          #748592
          peak4
            @peak4
            Just tried my 2004 paper catalogue, but nothing listed.
            Anyone got a 2005 or 2006
            Bill
            #748598
            DMR
              @dmr
              I have an earlier (1995) catalog that lists 266-884 as being from Eurotherm Drives
              Dennis
              #748642
              john fletcher 1
                @johnfletcher1
                Many thanks to Robert, Andrew and Dennis, for responding to my request. I now have a copy of RS data sheets. In its day it was call by RS an “ac motor speed controller”. The inverter is more than 30 years old and was pre owned as the car sales man says, can’t grumble at that. John
