Hi, I need to cut a keyway in the bore of an aluminium alloy pulley for a wood turning bowl lathe drive.
I am planning to do this on my Boxford lathe by making up a boring bar to almost the bore size and fitting an adjustable cutter near to the end so that I can use it as a broach, a little at a time.
Any advice, please as I haven't done this before.
Two specific questions:-
Is it sufficient to lock the faceplate by engaging the back drive as well as the mandrel drive pin?
Do I need a leadscrew handle, or should I just use the saddle handwheel?
Thanks in advance
