Posted by not done it yet on 13/07/2023 20:19:32:
Ep90 gear oil? Do be careful that it doesn't contain extreme pressure additives that eat yellow metals.
I wasn’t aware that there was any form of oil pump in those Fairey overdrives. Are they not just splash lubricated? I had two fitted to my Series lll – one always ran very hot and its replacement was a far better unit (ran cool and drive selection was far smoother).
Hopefully my comments re GL4 and GL5 oils cover this.
As to the "pump" concept, the main output gear is drilled radially with small holes in the lands at the bottom of the teeth. Hence oil brought up from the sump riding the gear teeth is squished under pressure through these holes as the teeth mesh, providing lubrication to the bearing inside.
Edit :
Bear in mind that oil for the final drive gear is from the sump of the transfer box. In theory this oil is kept separate from that in the bottom of the overdrive so hopefully the cooling of the inside bearing is better.
Edited By Simon Williams 3 on 13/07/2023 20:53:24
