Insulating board that won’t drop powder as it is touched
Home Forums Beginners questions Insulating board that won’t drop powder as it is touched
  • #10139
    Chris TickTock
      @christicktock
      Chris TickTock
        @christicktock
        hi, i am currently making a small tempering / bluing box using a PID controller and ceramic heater.
        the insulation is a bit of an issue. Ideally I would like it to be 25mm thick but less will not hurt. i dis some reseach and went fot Calcium silicate for its insulation characteristics. the box will be heat to around the 300 celcius point..
        The issue with calcium silicate is it is so powdery i can see each time i take off or put on the lid white powder will drop in.
        So has anyone any ideas of an alternative. There's vermiculite but is this as bad for crumbling/ how about fibre cement. The idea is to keep the heat in to reduce heat up times and help maintain a constant temperature as much as possible.
        Hope you are all well.
        Chris
        #460721
        David George 1
          @davidgeorge1
          You can try these as they make an insulation board which is a mixture board.
          2. COMPOSITION CAS NO.
          Synthetic calcium silicate hydrate 1344-95-2
          Mica 12001-26-2
          Vermiculite 1318-00-9
          Cellulose fibre 9004-34-6
          Company: Promat UK Limited
          Calcium silicate board containing the substances The Sterling Centre, Eastern Road
          detailed below Bracknell RG12 2TD
          Tel: 01344 381400 Fax: 01344 381401
          David
          #460722
          John Haine
            @johnhaine32865
            Jake Sutton, a brilliant clockmaker, described using a bluing box in Horological Journal last July and mentioned a useful mod to reduce the heating of the outside of the housing. This was to use Rockwool-type roofing insulation rather than vermiculite.
            #460726
            Chris TickTock
              @christicktock
              Posted by David George 1 on 29/03/2020 13:49:14:
              Mica 12001-26-2
              David
              Thanks David, I think it might well be an idea to give these people a call tomorrow and pose my question of what is not going to drop powde inside/
              Chris
              #460732
              Johnboy25
                @johnboy25
                I’ve been looking for mater for a similar application. Thanks for the ‘heads up’ on this one.
                I’ve found a link on t’internet:-
                John.
                #460733
                Johnboy25
                  @johnboy25
                  John.
                  #460748
                    The under face of the insulating lid can be protected with a thin steel sheet to stop powder crumbling off. Ideally polished stainless, but ordinary tin-plate will do. (Old biscuit tin.)
                    Although the sheet will get hot inside the oven the outer insulation will still work as normal. Whilst the steel sheet absorbs a certain amount of heat, keeping it thin means it won't waste much.
                    The sheet could be secured to the insulating lid by a small diameter stainless steel* bolt. A convenient wooden handle could be attached to the bolt on the cold side.
                    Though the steel will cool fairly quickly, take care when handling the hot lid!
                    * Stainless conducts heat much less well than ordinary steel.
                    #460749
                    noel shelley
                      @noelshelley55608
                      I have 2 full sheets of A60 insulation board. The modern equivalent of asbestos sheet 12 or20 mm thick. Not as efficient as silica or ceramic fibre but solid. I can let you have some for a few beer tokens ! Ceramic fibre with a rigidiser would work or even a pre formed tube, this would make it easy to construct. PM me if I can help. Noel
                      Then on reflection by far the best idea would be American K23 firebricks in a thin steel box. These can be cut with a knife or hacksaw and glued together with air setting cement. 3" will keep 1500*c in. It's used in the lining of pottery kilns Etc Bricks cut in half would give you1.5" thickness.There so light they will float.  I built a furnace 25 years ago of this material, carted it all over the country and it's still going strong.  N.
                      Edited By noel shelley on 29/03/2020 15:47:33
                      #460751
                      Joseph Noci 1
                        @josephnoci1
                        Do you have a product called Pratleyperl in the UK? It is made from the mineral perlite. A really remarkable thermal insulator and is mostly used in bead form and laid on your ceiling for insulation. It is also used mixed with cement to plaster house walls for insulation, which I have done to my house on the Namibian West Coast and the result is great – huge reduction in heating/cooling requirements. . Raw beads weigh about 100kg/cubic meter. Also, mixed with cement, used to insulate ovens, furnaces, cryogenic storage, etc.
                        Basically mix, dry, with cement in 3:1 volume, then add water till a firm mix, and form into the shape you want. A test I performed was to make a 25mm thick slab, about 200mm square, and cure well. An Oxy-Acetylene hot flame played onto one face till the surface was orange/red, with the flat of my hand up against the opposite side – warm but far from uncomfortable to keep my hand there!
                        You can make any shape you want, and it does not seem to powder much, unless you rub two like surfaces together.
                        The only heat insulator that would not do that is probably in the family of ceramics.
                        Joe
                        #460762
                        Bazyle
                          @bazyle
                          This is a very low temperature so why not use vermiculite board? Stands up to hot red heat and at 300c won't even tarnish.
                          #460773
                          Chris TickTock
                            @christicktock
                            Posted by Bazyle on 29/03/2020 16:20:18:
                            Thanks Guys,
                            Lots of ideas here. Is vermiculite less powdery than the calcium silicate, if it is fine.
                            Chris
                            #460778
                            Dick H
                              @dickh
                              Would painting with a solution of water glass (sodium silicate) solve the problem?
                              #460793
                              duncan webster 1
                                @duncanwebster1
                                Vermiculite board is the stuff CuP alloys sell to make brazing hearths, see **LINK**
                                #460803
                                  Vermiculite/skamolex will be fine, the only thing that spoils it is getting flux on it.
                                  #460854
                                  Chris TickTock
                                    @christicktock
                                    Posted by Neil Wyatt on 29/03/2020 18:21:43:
                                    Thanks Neil,
                                    I guess the thing to do is try vermiculite.
                                    Chris
                                    #460860
                                    John Haine
                                      @johnhaine32865
                                      Rockwool? After all someone who has made one recommends it.
                                      #460862
                                      Chris TickTock
                                        @christicktock
                                        Posted by John Haine on 29/03/2020 21:37:25:
                                        Thanks John,
                                        Rock wool is on my radar though its lack of total rigidity needs to be appraised. In the design I am using the hot plate will sit on the insulation as well as the lid. Is it rigid enough…that is the question, it certainly solves the powder issue though.
                                        Chris
                                        #460882
                                        Bazyle
                                          @bazyle
                                          Another angle is to make a thin stainless steel box or find a suitable shape in cooking utensil and surround with rockwool. Need some kind of asbestos paper substitute Kaowool? for electrical insulation or are you making a big box with a hot plate inside it?
                                          #460889
                                          Alan Charleston
                                            @alancharleston78882
                                            Hi,
                                            I would agree with Dick that painting it with a solution of water glass (sodium silicate) would fix the problem. Years ago I made a small oven for use in a lab and it was insulated with a putty of powdered asbestos and sodium silicate solution. It was plastered on and dried by turning the oven on. The surface was stable and I used it for years.
                                            Alan
                                            #460897
                                            Chris TickTock
                                              @christicktock
                                              Posted by Alan Charleston on 30/03/2020 06:44:54:
                                              Hi,
                                              Alan
                                              Thanks for this at first glance it didn't seem plausable but if you second it it must be. Also carbonising it apparently may help. a little experimentation as always may be a good idea.
                                              Chris
                                              #460904
                                              John Hinkley
                                                @johnhinkley26699
                                                Chris TT,
                                                If you want to while away an hour or two, head on over to Shadon HKW on YouTube and have a look at his series of videos describing the design and build of the heat treat oven he has built. Admittedly, he is making them for sale, but you might get a few useful ideas from his experiences. No.1 video starts here :
                                                Heat treat oven
                                                He is using a refractory brick to line the oven, but it's some while since I viewed the videos and I can't remember exactly what is specification is. It's easily cut – he says with a bread knife, even – and seems quite stable once installed.
                                                Rather than use a lid, his design is a heated box with a hinged door on the front, which seems an eminently sensible solution to me and I would have thought gives easier access to the hot components, too.
                                                Oven Man
                                                  @ovenman
                                                  All commercially made laboratory and industrial heat treatment ovens going up to around 600C have stainless steel liners to overcome the dust problem. As most have a circulating fan the abrasive effect of the air on any soft insulation is disastrous. For high temp use back the stainless with 25 mm of ceramic fibre and then a layer of mineral wool slab about 50 mm thick. If you want a nice cool exterior build a double skin case with a ventilated airgap. For a simple home built job vermiculite board is probably as good as it gets for non shedding material. If you are using stainless for oven building go for ferritic 430 rather than austenitic 304, it doesn't expand as much.
                                                  HTH Peter
                                                  #460942
                                                  Chris TickTock
                                                    @christicktock
                                                    Posted by Oven Man on 30/03/2020 10:09:27:
                                                    HTH Peter
                                                    Many thanks Peter, all points noted
                                                    Chris
