Posted by MikeK on 04/02/2022 23:15:08:
In a recent thread someone from ARC Euro commented that "hitting (shocking) the arbor into the chuck with blow hammer… not ideal method, but just done for the purpose of these pictures".
Which is what prompts me to ask: "Okay, what is the ideal method?"
Look at it from the perspective of the designer. It's useful to make drill chucks that will fit any number of machines and useful for machines to take any tool. Ideally the answer should be simple, cheap, accurately resettable, and reliable. Tapers are a good solution because tapered plug-sockets provide a high-friction joint by wedging together, and it's easy to make adaptors that fit accurately along a radial axis.
Tapers are often used as a quick release mechanism. This variety needs to be tight enough to not slip, but loose enough to remove without drama. Over-tightening them is a serious sin, and being slapped in the face with a wet fish is inadequate punishment.
The other type, such as drill-chucks, are rarely removed from their arbours, perhaps never, so little harm done by fixing them firmly. An effective way to do this is to deep freeze the arbour whilst warming the chuck in an oven. Then quickly assemble the two and tap home once with a dead-blow hammer. The arbour expands on warming while the chuck contracts on cooling – the forces involved are enormous.
Firmly assembling a taper is declaring there's no intention to break the joint in future, which is usually fine. I suspect it's mostly amateurs who remove drill-chucks, either because they like repairing and re-using things, or are too careful with their money to buy two! Anyone making a living by cutting metal is less likely to waste time mending old tools or swapping arbours. Pairs of wedges are sold for removing drill-chucks, though I haven't seen any recently?
Drilling tends to tighten the taper, so no need for anything else unless a big drill does something unusual like widen an already big hole. (Lots of twist coupled with low down pressure.) Milling is different! It applies sideways forces and vibrations which tend to loosen the joint, so the taper has to be held firm with a drawbar.
My drill-chucks were all attached by plonking the chuck body head-down on a bench, pushing the cleaned arbour firmly into the cleaned chuck, and a single sharp tap on the arbour. None of them have ever come loose. I've only once needed to remove a drill chuck. It was after accidentally attaching a new one to the wrong arbour…
