Yes they tend to tilt the tip so that the edge won't rub on the cut surface, more noticeable as the bar gets smaller
Cutting tip at Ctr Height.
Yes OK on aluminium with the supplied tip which was most likely a CCMT………. but you will get a better cut with an aluminium specific CCGT……… tip
