John,
I've been building and operating model locomotives for over forty years. I've never put a pump (hand or mechanically operated) on any that I've built. I've had few failures attributable to the injectors except in the early days when I quickly learnt a lot about them, but with two to work with I never got into any real trouble.
Looked after injectors are very reliable. With check valves that seat properly, and that's just one per injector, and adequate steam and water supplys with good fine filters you should have no problems. Don't be lead by anyone into believing that they need to be removed after every outing to be cleaned in acid. I only do this if an injector shows signs of misbehaving, and after checking for dirt in the cones, and I only use citric acid – never vinegar. I once had a loco laid up waiting for mechanical repairs for two or three years. When I eventually got the work done and the boiler tested, both injectors worked flawlessly although they hadn't been cleaned in years.
Always make sure there's no water lying in the injector when the loco is out of service. If not then the cones are subject to de zincification and will quickly be eroded. A squirt of WD40 after running is over ensures they are dry.
Don't oversize the injectors. They need to be operating for long periods. If you have injectors that are too big they will fill the boiler too quickly and you will be forever turning them on and off. 11ounce per minute will suffice on even large 5" gauge locos. You just turn one on when you set off and use the other to top up if you need to. The more you use them the better they get.
And a word of warning. If you have a pump and an injector the injector will give you problems because it won't get used enough, and if the pump suffices then you will neglect the injector and it won't work when you need it.
Finally lifting injectors operating in the submerged position are the best. It doesn't matter if you turn on water or steam first, and if the water suppy is interupted they will restart automatically.
Hope I've convinced you. Good luck
Eddie
Edited By 61962 on 24/01/2013 22:44:38
Edited By 61962 on 24/01/2013 22:45:09
