Hi
Yesterday I took the injector off my 5" gauge loco to give it a good soak in citric acid to clean it up.
Two cones have appeared in the cleaning dish. They were a loose fit in the injector, held in place by the pipe connections (Steam in and feed to boiler).
My problem is that one injector cone has a slightly longer and thinner end (the internal end) profile than the other.
Can anyone suggest which end is likely to be the steam feed end cone and which the output to boiler cone so I can re-assemble correctly?
Many thanks
