Info’ that might be of use to Warco Lathe owners.
Home Forums Manual machine tools Info’ that might be of use to Warco Lathe owners.
  • #602465
    Bo’sun
      @bosun58570
      Good afternoon,
      I've had my Warco WM250 for over a year now, with an outstanding warranty concern regarding "carriage lift" of around 0.018mm. Outstanding because of Warco supply issues and a domestic issue.
      A 0.015mm feeler gauge inserted in the gap appeared to give satisfactory results without binding. So I set about removing the clamps to machine some material off and reduce the gap. However, all four bolts (two each side) were found loose. Simple I thought, just tighten them up, but tightening them up just locked the carriage. For the time being, I've been operating the lathe with them just tight enough to remove the lift without binding. I now have to work out a new machining regime. Seems strange to have a Gib at the rear of the carriage but nothing at the front.
      Also, I found the two tailstock adjusting screws loose.
      Bo’sun
        @bosun58570
        Carriage lift and Tailstock loosness
        #602490
        Nigel Graham 2
          @nigelgraham2
          Well, if you go and modify any of it, you can't then fairly expect Warco to repair it under guarantee even if they are happy to extend the warranty to cover their supply problems ….
          Are there no lock-nuts on the adjusting screws, or are they grub-screws?
          #602495
          Bo’sun
            @bosun58570
            Hello Nigel,
            Now that I've got a fix, I'm not going to pursue the warranty claim. That also avoids a whole lot of lifting, repacking, unpacking, more lifting and realigning.
            The fixing hardware is just ordinary socket head cap screws.
            #602497
            ChrisB
              @chrisb35596
              My WM280 had the same issue, so probably they are designed that way. I put shims under the clamp until I could feel a slight drag when sliding the carriage by hand and tightened it down.
              #602502
              Bo’sun
                @bosun58570
                Hi ChrisB,
                You maybe correct, but it would have been nice to see some reference to it in the operators handbook (or maybe not, seeing how much other useful info' has been omitted).
                The design is more likely so they can produce cheaply with wide tolerances.
                #602506
                  Posted by ChrisB on 20/06/2022 18:07:09:
                  If this is what I think it is, I don't think its a fault.
                  The rear of the saddle is prevented from accidental lifting off but the feature doesn't steer or contribute to the saddle's accuracy. Accuracy is provided by the polished top of the prismatic bed, on which the saddle is machined to accurately slide, not the rougher surfaces below.
                  Normal cutting forces don't lift the saddle off the bed, they press it down. I think reducing the gap so the saddle actually touched underneath would reduce the lathe's accuracy by nudging the machined parts of the saddle off the machined parts of the bed.
                  Did the gap actually cause a problem when cutting metal, or is it just a worry that it might? Not an issue on my WM280, but perhaps I don't take the sort of cuts that might lift the saddle. Such as parting off with a rear tool-post such that the cutter is pulled up rather than pushed down, maybe?
                  Mick B1
                    @mickb1
                    That 0,018mm 'lift' is about 7 tenths in old money.
                    Presumably you mean vertical play in the carriage?
                    I've had my WM250V for over 7 years now and never been aware of such a thing, nor given any thought to how I might measure it, what it might do, how I might fix it or whether it's worth doing so.
                    I can only imagine it might have some effect when there are upward forces communicating to the carriage, such as when turning in forward rotation from an RTP, or milling the underside of a component in a vertical slide – something I did successfully and AFAIK with decent precision only yesterday.
                    Now I don't know whether I should be worried about it.
                    #602509
                    ChrisB
                      @chrisb35596
                      Posted by SillyOldDuffer on 20/06/2022 18:58:51:
                      Have you ever had a look at the mating vee groove in the carriage? If I had to cut it with a hacksaw I would have probably done a better job!
                      #602516
                      Norfolk Boy
                        @norfolkboy
                        Posted by ChrisB on 20/06/2022 19:31:38:
                        I had to smile when I read that, the vee ways on my Warco simple surface grinder are the same, look like they have been carefully scraped by an angle grinder with a masonary disc. You kind of get what you pay for I think, it's whether the sum of the frustrations defeats you in the end.
                        #602519
                        Tony Pratt 1
                          @tonypratt1
                          Do you know what, the lathes are obviously copied from European models maybe Emco & the build quality is shocking in the extreme but they do cut metal & my Warco 290V also cuts parallel. cheeky
                          PS my inverted vee ways are not 90 degrees so not sure where they touch each other or what the angle is meant to be, they must rely on 'point' contact only!
                          Tony
                          Edited By Tony Pratt 1 on 20/06/2022 20:54:04
                          #602528
                          ChrisB
                            @chrisb35596
                            Don't get me wrong, I'm quite happy with my lathe. It does what I need and more. But if you look closely you'll find it's a bit roughly finished, still happy considering the price.
                            #602541
                            Dave Halford
                              @davehalford22513
                              That being so why do I have 15thou wear on my Rockwell Delta rear saddle clamp ?
                              #602547
                              Hopper
                                @hopper
                                Posted by Dave Halford on 21/06/2022 00:01:36:
                                Possibly from 15 thou of combined wear on the top surface of the bed and the surface of the carriage that runs on the top surface of the bed, lettting the whole carriage drop down, creating the gap on the lift plate?
                                Or possibly it left the factory like that? Wiith the Delta's long carriage "wings" extending forward of the toolpost it is hardly going to tilt the carriage when cutting with the topslide extended forward. Usiing a long boring bar would be about the only time any force was put on the carriage that might lift the back end of it a bit.
                                Or possibly from swarf ingress causing wear on the lift plate surface?
                                #602548
                                Hopper
                                  @hopper
                                  Posted by Bo'sun on 20/06/2022 15:56:46:
                                  Good afternoon,
                                  Good luck making a warranty claim on a .015mm gap there. That is about oil film thickness and will be deemed within spec. If you really want to close it up, do as you have and semi-tighten the bolts. Even better, cut a piece of shim of the correct thickness and put between the catch plate and carriage. A piece of .02mm shim should do the job. A piece of paper cut like a gasket might even do the job. But you then have to be sure that the bed surface is runs on is perfectly parallel to the top surface the carriage sits on, otherwise you will get binding at one end of the bed or the other.
                                  It's unlikely to affect the performance of your lathe terribly except when the topslide is advanced so the tool bit is beyond the leading edge of the carriage, or when a boring bar is stuck out the front of the carriage. Possibly when taking interrupted cuts too. If using a rear parting tool, you should have the carriage locked anyway.
                                  Edited By Hopper on 21/06/2022 04:08:19
                                  #602562
                                    Posted by ChrisB on 20/06/2022 22:01:16:
                                    Not necessary to look closely – they are roughly finished! But they're a modern design, and although clearly made-down to a price, they're generally good enough where it matters.
                                    One of my old books, aimed at industrial purchasers before 1930, is highly critical of a British bad attitude to machine tools generally. Old-fashioned, out-of-date, conservative firms assumed best buy lathes were heavy old-fashioned manual lathes expected to last 60 years or more. Well-finished, beautifully made, hideously expensive, required highly paid skilled operators, and had to be ordered 6 to 12 month in advance. For this the owner got a wonderful machine and low-productivity, unable to compete with firms who had modernised at home or abroad. The book advises buying machine-tools designed to work hard for up to a maximum of ten years, then replacing them with whatever was best at the time: capstan lathes, then mechanical and hydraulic automatics, through Numerical Control, CNC, CAM, and multi-axis machine centres.
                                    The Myford ML7 is a good lathe, but it can be criticised on cost-grounds. Several features could be simplified, and money could be saved by not bothering with the finish, as was done to British lathes made during WW2 – spartan, but fully functional, made to do a job of work, and paying no attention to pride of ownership. Far Eastern hobby lathes are in the Spartan camp – aggressively priced to suit Model Engineer's notorious for not spending money! The machines work reasonably well and the price point make them attractive compared with better finished, but costly western alternatives.
                                    Much criticism of Far Eastern gear is based on look and feel rather than how well they cut metal. Comparing cylinders turned on various lathes In a double-blind test, I don't think it would be possible to identify which lathe produced which cylinder. However, in hobby workshops, the output often isn't the be all and end all! The owner may well have other goals. Good-looking smooth sliding tools increase confidence, productivity and pleasure, especially if you like everything to be 'just so'. In contrast, I don't care much about warts provided equipment does what I need, or as Chris puts it keeps me 'happy about the price'. Others, more power to their elbows, are sensitive to finish and seek perfection in their machines. Some folk worry about having their kit painted the correct colour: not me!
                                    Main thing is to enjoy the hobby, however it takes you!
                                    Hopper
                                      @hopper
                                      Posted by SillyOldDuffer on 21/06/2022 08:49:22:
                                      It certainly can be, but it must be remembered it was developed and sold as a low-cost hobby lathe. It was quite a few pounds cheaper than the Drummond/Myford M-Type that it replaced as the Model-Engineer's favourite and massively cheaper in later years than rivals such as Boxford and Raglan. .
                                      #602565
                                      Dave Halford
                                        @davehalford22513
                                        Posted by Hopper on 21/06/2022 03:36:59:
                                        Might I suggest that it's more about controlling the weight of the apron, which pivots about the front of the bed. The only thing that stops this is the apron power shaft/shafts, which will be subject to unnecessary wear without the rear 'clamp'.
                                        I don't believe that in todays constant drive to remove cost it would still exist if it didn't do something, just because some europeans put it there back in the day the design was copied.
                                        #602572
                                        Clive Brown 1
                                          @clivebrown1
                                          +1 that a carriage lift of 0.018mm is not really significant, but I wonder if the quoted measurements are wrong. Th OP refers to using a feeler gauge of 0.015mm inthe gap. If such a thing exists, I've never seen one.
                                          #602579
                                          Bo’sun
                                            @bosun58570
                                            From OP,
                                            Oops, should have read 0.18mm. Thanks for your observation Clive.
                                            Yes, I agree with other posters that 0.018mm is insignificant.
                                            However, I am concerned about finding loose screws.
                                            #602582
                                            Hopper
                                              @hopper
                                              So put some shim under the plate and tighten the bolts and it shold be ok.
                                              #602588
                                              ChrisB
                                                @chrisb35596
                                                Posted by Bo'sun on 21/06/2022 11:49:38:
                                                From OP,
                                                My understanding is the screws are loose on purpose, just to take up the slack. I only noticed they were loose when I had to take the carriage apart due to a crash. Didn't think much of it at that time, thought they must have come loose during use, but tightening them down during assembly the carriage got stuck. So I reasoned the clamp should have been shimmed, and that's what I did. Probably it was not necessary as some have commented.
