Hi all
It may be just me but I find all the permutations of indexable tool holders and inserts very confusing ( may be my age ), I need to make something quite large well large for me anyway out of brass , I usually only make brass parts using the hand graver but as the part is to large and I have the Myford equipped with the Rocketronics ELS I thought I may as well use it because the part I need to make is a radius, anyway the problem is I have been using a glanze SCLCR holder with
CCMT060204 inserts and been getting brilliant results on steel and stainless but I need an insert with negative rake for brass and I think aluminium, can I get an insert with negative rake to go into the holder or do I have to buy a different holder.I had been using eccentric engineering tool but I found that although it was good for most things when using the ELS it was okay for the first few cuts when it started getting more than 2 mm of shoulder it would jam and stop the lathe also damaging the part in the process so I sold them and I don’t get any problems with the above tool and getting a superb finish.
