I am planning to make an indexable dovetail milling cutter for making toolholders for a quick-change toolpost. I have found several articles on the web, but it seems many have problems with making the width of the dovetail on the toolholder of the exact dimension. (Measure-cut-measure-cut…..)
My question is, would it be possible to make the dovetail cutter so that it would cut both sides of the dovetail at the same time (like a woodruff cutter does)? I could then make the dovetail cutter to suit the width my QCTP use, and it would be very easy to make new toolholders – no measuring necessary. It would of course be necessary to mill out most of the dovetail using straight endmills, but the final dovetail using the dovetail mill.
Or maybe this cut will be too heavy for the dovetail cutter – I could use a smaller dovetail cutter on each side, and then finish off with the large dovetail cutter giving the correct dimension??
Many questions – do you have some comments?
Regards from Sverre (from Norway with a heavy snow storm outside!)
Edited By Sverre Evensen on 02/02/2010 22:01:25
Edited By Sverre Evensen on 02/02/2010 22:02:13
