My clock is held up on working out gear trains for a while so got side tracked. If I make one I want something that is pretty precise. To me that means no need to adjust until the clocks change and minute error over that period is ok.
The best option as I see it is an electric remontoire of some sort. There is a catch though. Most methods have some sort of error so the the re energising interval can only be so long. If it's pretty short there will be some small short term variation at say the seconds level but this will be evened out by the remontoire being "rewound" and also taken care of when the rate is adjusted.
With this set up the remontoire is driving the clock and can be put in different places but the further away it is from the pendulum the more scope there is for friction variations.
For an electric impulse I would be tempted to look at either precise crystal oscillators or a radio derived time signal from an atomic clock but the same idea of keeping the impulse rate interval short could be used with the Hipp arrangement. I have been wondering about dismantling a relay to get a suitable low power solenoid for that but it's rather hard to decide just how much power is needed. The design i have seen uses a pretty hefty one and I have no interest in wiring to the mains or needing to fit batteries often.
A spring driven clock where the spring rewinds the remontoire can also work out but the interval it takes to actually "rewind" it will vary as the spring winds down. An answer to that might be to use a weight and rewind that periodically with electronics. So far that looks to be the most sensible answer but can I get it to rewind at night when I am asleep and in bed – maybe.
I don't want to hear a motor whirring away when it rewinds.
