I'm another satisfied user of the Nu T belt – on the primary drive on my Super 7. These belts do stretch until they stabilize, but, as has been said, removing a link is easy and quick. I don't think it's been mentioned that they are supposed to run only in one direction, but, in practice, reverse running is OK. They are noisier than a sweet-running V belt, but don't seem to have the problem that some V belt drives can have, when a too-slack, vibrating belt is tightened, only to 'drum' annoyingly and incurably. This is said to be because of the link belt's higher internal damping characteristics. One might therefore expect a link belt to run hotter than a V belt, but, perhaps because of its greater flexibility (than some types of V belt), this doesn't seem to be a problem in practice. And they don't seem to degrade. I don't know whether they wear alloy pulleys more than conventional V belts though.
The rivetted Brammer belt is perhaps best regarded as obsolete. I have a sneaky suspicion that the rivet-contacting-pulley problem is because the wrong section belt is sometimes sold.
