School science lessons, we used "Celsius" except when mentioning "Centigrade Heat Units". How daft can it get?
Taught decimetres but they seem to have fallen by the wayside as never see them mentioned anywhere.
Whilst I think there is some merit in keeping the number of different measuring sizes to a minimum, I think that mm, cm and metres could be used in a sort of prortional way. Vehicles being big objects, why not quote length as say, 19.8m and a person's height as 180cm. Kitchen worktops 60cm but say 50mm thick.
Cross sections of most things could be in mm, except when they get much bigger like diameter of a large tree trunk in cm.
All much better than yds., ft., ins., with the cock-eyed quantities of units making up the next larger unit.
As I've previously stated, I try to work with what I'm given on a drawing. If drawing is metric, use metric sized materials where possible and if necessary, convert an Imperial sized piece to metric before using it. All helps to avoid errors and makes life simpler.
Likewise, with Imperial drawings, use Imperial materials as far as possible and convert an odd piece of metric material to Imperial size before using it.
When I started constructing HH's t&c jig, I couldn't source the specified metric sized pieces of steel in the small lengths required. Our usual suppliers didn't seem to stock what I wanted but Joe at Maccmodels came up trumps with some and another poster on here suggested a business in Hampshire, does traction engine stuff, but cannot remember their name. Sods law operating, I will remember immediately after I add this post! I think things are starting to improve, possibly due to an increase in demand for metric materials.
