Imperial v Metric Measures
Home Forums The Tea Room Imperial v Metric Measures
Viewing 25 posts - 1 through 25 (of 89 total)
  • #593608
    DMB
      @dmb
      My latest order, one of many, list as long as your arm, from a certain ME supplier. His label on the bottle of cutting oil reads "500ml", which I'm willing to believe. But! His label is stuck on top of his oil supplier's and peeping out, just below his label, is a measurement of quantity from his supplier: "1.056 quarts"Oh really? So his supplier thinks more than 2 pints = 500ml(1/2 a Litre)! Whoever Rockoil employ obviously didn't go to my school who taught me that a Quart is 2 Pints! My supplier's halo not slipped but his has.
      Much like a very nice one – off( not part of a set) favourite saucepan in the kitchen from a well known chain of small shops. Yet again the retailer is innocent, it's his supplier employing staff who are probably too young to have been taught these measurements. Inside has a ladder type scale marked, 0.5L, 1.0L,1.5L, 2.0L on the left and to the right, trailing slightly lower, 0.50QT, 1.0QT, 1.5QT and finally, 2.0QT. This had me foxed for ages until the confused lightbulb suddenly lit up! QT means quarts but again, 0.5L is approximately a pint and 2.0L is 3.52 Pints, not slightly more than 2 Quarts!
      These quaint medieval measures should have been scrapped long ago. I frequently walk to a M&S shop for their milk as it tastes better than similar from the Sainsbury's opposite them. Asda and Tesco's similar (semi skimmed) also on a level with Sainsbury's. I reckon it's down to "food mileage". What else? It's marked as 2 Pints and 1.036L, suggesting that they're supplier is using Imperial. Some of the others' bottles are marked 1L and the equivalent in pints, so they're different supplier(s) are using metric.
      What a mess to put it politely.
      On my walk to M&S, I walk under a railway arch, Brighton" East Coastway " to Lewes, Eastbourne, etc. Arch has enamel plate stating number of Chains, presumably from main Brighton Station. Why Chains? Someone in railway infrastructure management wants throttling with one! About time they joined the 21st Century and used Metres.
      BTW, I've been left school a little while now – 70+ 'old codger' but I can easily cope with changes. Just wish overpaid people for whom we voted, would make decisions.
      DMB
        @dmb
        #593610
        DMB
          @dmb
          Just as crazy, new car, 17ft long is described as being 5181.6mm. I can more or less visualise 17ft but not that ridiculous quantity of mm.
          About the limit in mm is 600, generally used to describe the depth of kitchen worktops. Why not 60cm?
          I would have thought that metres would be best size unit for a car's length and perhaps, call me 178cm, not 1.78m tall.
          Edited By DMB on 08/04/2022 21:58:24
          #593613
          Clive Hartland
            @clivehartland94829
            European countries use different methods of describing metric lengths, in the UK we don't use cm. but measure as say 1.50mtrs or 1500mm.
            having worked in a Swiss company one had to be bi metric/Imperial minded. So your height is 1.78 mtrs.
            Buy some wood, its meters length but mm cross section.
            #593615
            Nick Wheeler
              @nickwheeler
              Posted by DMB on 08/04/2022 21:45:56:
              You do know that Rockoil is American? And that a US pint is only 16 fluid ounces? Which means that one US pint is 0.474ml.
              Does it make sense now?
              Although using metric is far more sensible.
              Edited By Nicholas Wheeler 1 on 08/04/2022 22:34:02
              Edited By Nicholas Wheeler 1 on 08/04/2022 22:34:27
              #593616
              Frank Gorse
                @frankgorse
                The US quart is 0.95 litres so that may account for the measurements in the saucepan. But,yes,it’s all a mess.
                Perhaps the railway plate dates back to the days when we were all taught things like chains?
                (Sent before I’d seen Nicholas’s post,above)
                Edited By Frank Gorse on 08/04/2022 22:40:09
                #593622
                Nigel Graham 2
                  @nigelgraham2
                  Network Rail does still use miles, chains and yards, judging by new-looking plates on bridges and level-crossings; and its speed-limit signs are in mph.
                  Apart from the Chain, the other units are compatible with British road practice in which the Statute Mile and Yard, and the Mile Per Hour, are the only legal units.
                  The cm is not a "Preferred Unit" – as engineers we all know it should be metres and millimetres except in a few specific applications. Why? 'Cos the ISO says so. Though I don't condone it – mathematical neatness does not always make for day-to-day practicality.
                  Nevertheless, quoting a car's length in mm is a foolish misuse of the system – and so is quoting its load space in litres and its engine power in some oddity called "PS" .
                  And Conversely, Clive's timber is correct in being sold as metre lengths of a X b millimetre section.
                  However, a length of 6mm-labelled mild-steel I bought recently is actually 1/4-inch dia. Serves me right for using B&Q! In fact it did not matter for the purpose.
                  I had to use the SI system at work but that was in Acoustics where the Pascal unit of pressure is reasonable, sort of, although uselessly small for tyres and boilers. Actually it's uselessly big for Acoustics: the linear scale for sound starts with the micro-Pascal (though converted to the deciBel, based on logarithms of ratios.) The quietest sound pressure-level we can hear – or could before our rock-concert and discotheque days? 0dB re[ferred to] 20µPa; i.e. a mere 20µPa. That is just one five-thousand-millionth of atmospheric pressure… giving whispered sweet-nothings barely audible in the boudoir, a rather awe-inspiring context.
                  In marine work 0dB is set at just 1 lonely little micro-Pascal; and the electrical sensitivity of a hydrophone to sound pressure is in so-many dB re 1 volt / microPascal. A right tangle if you re-write that it in full, in its SI fundamental units!
                  I am sort of used to both systems, but slip between them for convenience at times.
                  For example, although my steam-wagon project is to approximate 4-inch scale of its English-made original, I am using millimetres to make the ash-pan parts to overall 7.25 inch width. Why? It's fabricated from 20x20x3mm angle, 1mm sheet-steel foldings and metric screws; designed mainly "on the job"; made mainly by hand tools and bench-drill; and marking-out in mm is simpler than in bits of inches. (I still make mistakes and revisions though!)
                  #593632
                  Colin Whittaker
                    @colinwhittaker20544
                    I went to my local wood shop in Phuket Thailand.
                    I'd like some 2cm thick planks says I. She pulls out a ruler squints and says OK 3/4 of an inch.
                    Right thinks I that makes my 20cm wide plank 6 inches. By 6 inches wide says I.
                    Out with the ruler again and she says that's 20cm.
                    I give her a funny look and say 2.5m long? Success!
                    It's a weird mish mash of length units out here. But the hard wood is very cheap and very pretty when stained/varnished.
                    Colin
                    #593633
                    PatJ
                      @patj87806
                      I work in the design/building industry in the States, and everything is feet and inches, although some components are designed and measured in metric, such as 3D modeled equipment.
                      Generally if metric is on the drawings, it is in inches/metric.
                      I had a question about the power line right of way extending over too close to a new building being constructed.
                      I measured from the power line pole to the building, and it was 40'-4".
                      Everyone knows what 40 feet is, and everyone knows how wide a 10' wide easment is.
                      Nobody would ever say "That building is 7,680 1/8ths of an inch off of that power pole.
                      Nobody would know what the heck that represents.
                      Breaking down the units into an impossbily small unit such as the mm is counterproductive in the construction world.
                      I am working on a lagoon that is 2,300 feet long.
                      Again, nobody would have any idea how big that is in metric.
                      Feet and inches is very convenient, usable, functional, and immediately understood any anyone in the building industry.
                      The metric-pushers don't have to build buildings and stuff is my guess, else they would revolt.
                      #593635
                      FMES
                        @fmes
                        Posted by Colin Whittaker on 09/04/2022 01:53:55:
                        Colin
                        20cm is 6inches?
                        My ruler must be well out.
                        #593636
                        Colin Whittaker
                          sorry 20cm is 8" give or take, I asked for 8 inches.
                          Edited By Colin Whittaker on 09/04/2022 04:23:54
                          #593647
                          Martin Connelly
                            @martinconnelly55370
                            PatJ, having worked in engineering all my working life I am used to working with metric and imperial measurements. I had to convert 40'-4" into metres in my head to visualise it. 40' is 12m (more or less) as there are 40" to the metre (more or less) and then 4" is 100mm or 0.1m. So you are talking about 12.1m. This is what the majority of the world will do as the idea that "Everyone knows what 40 feet is" is clearly wrong and very USAcentric.
                            Martin C
                            #593648
                              Posted by DMB on 08/04/2022 21:54:43:
                              Simply because the system does not include ‘centi’
                              The cm is only a ‘customary unit’ … it is now deprecated
                              https://www.nist.gov/pml/weights-and-measures/metric-si/si-units
                              https://en.wikipedia.org/wiki/Centimetre
                              Edited By Michael Gilligan on 09/04/2022 08:15:16
                              #593650
                              Gerard O’Toole
                                @gerardotoole60348
                                Posted by PatJ on 09/04/2022 03:22:51:
                                I …
                                Yes, If only we Europeans could get rid of the metric system we too could have buildings and roads.
                                #593652
                                Andrew Tinsley
                                  @andrewtinsley63637
                                  Can't work out what the fuss is about, as far as units are concerned, I am ambidextrous,
                                  Andrew.
                                  #593656
                                  Les Jones 1
                                    @lesjones1
                                    USB power banks always seem to be rated in mAH. So a 10000 mAH one is really 10 AH.Will the marketing people start to rate them in uAH to make them look bigger. So a 10 AH one would then be called 10000000 uAH.
                                    I remember when metrification first came in I went to by some 6 foot lengths of 2" x 1" I said I want some 6 foot lengths of 2 x 1 but I assume now that will 2 metre lengths of 50 x 25 mm. I was told that they still sold it by the foot.
                                    Les.
                                    #593662
                                    Nick Wheeler
                                      @nickwheeler
                                      Posted by Andrew Tinsley on 09/04/2022 08:58:12:
                                      Andrew.
                                      Yeah, that.
                                      Once again, we have the ridiculous idea that feet and inches are somehow natural and intuitive, whereas mm and metres aren't. Our brains aren't naturally tuned to recognise 17feet, they're trained to do that. Whereas anyone who grew up with metric is just as capable of visualising 5171mm or 5.2metres. For the same reason.
                                      Use them enough and you'll be able to do that with both systems, simultaneously
                                      #593664
                                      Martin Connelly
                                        Missed this one.
                                        I am working on a lagoon that is 2,300 feet long. Again, nobody would have any idea how big that is in metric.
                                        Well 10 feet is about 3m so 2,300 is about 3x230m = 690m. The correct statement is a lot of people in the USA will have no idea how big 690m is.
                                        Martin C
                                        #593665
                                        Swarf, Mostly!
                                          @swarfmostly
                                          This may be slightly off-topic:
                                          I happened to look at the rating plate on one of my frownHi-Fi loudspeakers the other day. It claimed that the speaker was rated at 120 Watts of 'music power'.
                                          Are 'music power' Watts metric or Imperial?????
                                          Best regards,
                                          Swarf, Mostly!
                                          #593666
                                          Sandgrounder
                                            @sandgrounder
                                            Also slightly off-topic
                                            The shop I used to buy hardware fittings from would sell you a 'pair of hinges' if you wanted 2 and 'one and a half pair' if you wanted 3, I don't know if that was a normal ironmongers expression or not.
                                              Posted by Swarf, Mostly! on 09/04/2022 09:44:39:
                                              ’music power’ is based on the assumed peak-to-rms ratio
                                              John Haine
                                                @johnhaine32865
                                                Please could we BAN any further discussion about metric v Imperial units. It's boring and wastes everyone's time.
                                                #593671
                                                Oldiron
                                                  @oldiron
                                                  Posted by Sandgrounder on 09/04/2022 09:56:39:
                                                  I remember reading many years ago an old woodworking magazine where it stated "use 1-1/2 pairs for heavy doors.
                                                  Cannot remember the magazine name but always remembered that quote.
                                                  regards
                                                  #593673
                                                  David Davies 8
                                                    @daviddavies8
                                                    Centimetres belong with dressmakers and schoolteachers. Engineers use metres and millimetres. Similarly radius is a concept used by mathematics teachers and turners. Engineers use diameter, —— Discuss.
                                                    Dave……tongue in cheek!
                                                    #593674
                                                      I work in the design/building industry in the States, and everything is feet and inches…
                                                      Everyone knows what 40 feet is…
                                                      Or maybe not! The USA has two definitions of the foot. PatJ refers to the common one, which is the International Foot, but the US also has a Survey Foot, used in mapping and to define land ownership. Although the difference is tiny, it often causes problems, and the US is dumping the Survey Foot in favour of the International Foot (defined as 0.3048 metres) at the end of this year. Although most of the population won't notice, it's an important change to those who need it, and long overdue. Many of those to whom survey measure matters were in favour of metricating, but resistance to change was too strong.
                                                      When it comes to assessing measurement systems it's extremely unwise for individuals to rely on a narrow work experience. A major flaw of the Imperial System is it creates pockets of illusion that nothing is wrong. Within narrow confines all seems well – building sites and engineering workshops do their own thing. Unfortunately, problems appear like a cockroach infestation when worlds meet. In WW2 the small difference between the US and British Inches caused endless compatibility problems : stuff that should have fitted together, didn't. Today, trade is global, and the metric system is almost universal – countries see more value adopting an international system rather than sticking to traditional measure no-one else understands. Non-standard products are a pain.
                                                      One fault of the Imperial System is it's full of conversions. 12 inches = 1 foot, 3 feet = 1 yard, 14 pounds = 1 stone, 1760 yards = 1 mile, etc etc. Another, it's internally incoherent, causing unnecessary disjoints between – for example – electrical and mechanical measure. (Power: one Horse Power is 550 foot pounds per second, with no obvious connection with Watts. Sums involving power are easier in metric, because the relationship between mass, length, and time is consistent within the metric system.)
                                                      Imperial is often slightly easier for basic niche work, but the metric system pulls away as complexity increases, and is universal. There's no difference between Building Site and Rocket Science.
                                                      Much worse in the past. We benefit from an Imperial System that's been massively tidied and simplified. Nonetheless, it's still not logical or internally consistent, and this causes grief as soon as anything complicated is tackled. Men with tape measures and micrometers aren't doing anything complicated, so Imperial seems all good to them. Scientists were first to dump Imperial in favour of a rationally designed system, and mathematical engineers soon adopted it too.
                                                      The main problem with metric is getting everyone on board. The English speaking world is full of objects defined in Imperial measure, that don't convert to metric in nice round numbers – window frames! So switching from Imperial to Metric is painful.
                                                      Countries that ruthlessly switched as fast as possible suffered much less pain than countries like the US and UK who chose to spread the agony over many decades.
                                                      In my opinion allowing a major technical improvement to be delayed by small-c conservatives wanting to buy potatoes in lbs was a serious failure of leadership. Buying spuds in kilograms might be a minor temporary discomfort until people get used to it, but lumbering designers with clunky mathematics and forcing British industry to try and sell Imperial machines to Metric customers damaged the national interest. And despite the advantage of a gigantic home market, US industry is also finding failure to metricate is a liability.
                                                      That large numbers of people are comfy with a wonky system is no reason to perpetuate it. If it's broke, engineers fix it. And they don't refuse to fix stuff because their little bit seems OK!
