Posted by Steve Crow on 02/07/2023 14:40:22:
I think that UNF and UNS might be the same thing…
If they were, why would there be two names for the same thing?
UNF is the standard Unified fine series. UNS is generally Unified special.
Also, it would be unusual to use fractional dimensions below 1/4" in Unified threads. Below 1/4", they are normally referred to by numbers (e.g. 10-24 UNC).
I think it might be unwise to try to fit the spindle nose into any series as such. A spindle nose is a different category of threaded item to a fastener.
Perhaps go through every fastener on the machine and list diameter and thread pitch. Hopefully you will find something that belongs to one series or the other but not both. It would then be reasonable to assume that the others belong to that same series.
