Imperial Thread Cutting on Metric Mini Lathe
Home Forums Workshop Techniques Imperial Thread Cutting on Metric Mini Lathe
  • #315911
      If you read to the bottom of the main page, they pre-grind the lead screws then roll them presumably to get the best of both worlds with ground accuracy and rolled form and surface finish.
      I think the 0.3mm per 300mm bit is an error as the text it's in mentions 60-degree metric form threaded rod rather than precision leadscrews and the 0.05/300mm is mentioned elsewhere and 0.003"/for for v-thread precision leadscrews.
      "Cold Rolled Formed Lead Screws
      Abssac supplies both machined and rolled thread formats. Lead screws that are cold rolled formed have the immediate advantage of a work hardened surface on which the load bearing nut will travel. Starting with a pre-ground bar stock, the thread form is gradually rolled into the material with increasing pressure ensuring precise material deformation along the thread form as it is worked. By repeating this process the screw stock work hardens into a smooth, polished like finish with the desired diameter and lead as the finished product."
      Edited By Neil Wyatt on 08/09/2017 15:33:57
      Bob Gitsham
        @bobgitsham90361
        Posted by Andrew Johnston on 08/09/2017 10:05:02:
        Posted by Neil Wyatt on 08/09/2017 09:47:50:
        Visiting this site I see their precision metric leadscrews have an accuracy of 0.08mm per 300mm.
        Hmmm, and further down on the same page they say the lead error over the length of the rod is 0.3mm per 300mm, rather different. I would expect precision leadscrews to be ground rather than rolled.
        Of course that doesn't change the fact that a 63 tooth gear is perfectly satisfactory for cutting metric pitches with the correct gear train. Personally I say hooray for quick change gearboxes; imperial, metric, DP and module all at the change of some levers, and one gear. thumbs up
        I have to agree wth "Personally I say hooray for quick change gearboxes; imperial, metric, DP and module all at the change of some levers, and one gear. thumbs up"
        That is the way it is on my lathe, and one of the reasons that I ordered that particular machine. No doubt there are a few obscure pitches that I will have to use extra gears for, but I might never need them.
        Bob.
        #315914
        Bob Gitsham
          @bobgitsham90361
          Posted by Neil Wyatt on 08/09/2017 15:28:41:
          Neil, I think you'll find that the pre-ground stock, is pre-ground round , to a size, then the complete thread form is rolled into it. Pre- grinding a thread form would be very expensive and probably no more accurate than their rolled form.
          #315919
            Maybe drifting off the original topic, but I think you might like this, Neil:
            https://www.helixlinear.com/
            Have a look at the blog post about plastic leadscrews surprise
            … I was quite impressed.
            MichaelG
