I think people sweat the metric/imperial stuff too much. For me, metric
is easier, for others, inches. All they are is measurements; the real
challenge is to make things, not to worry about units.
Agreed.
Just missed metrification at school – I did all Imperial, my 18 month younger brother was all Metric.
Apprentice training & early work experience was mainly Imperial – later work was mainly Metric.
Currently I work almost exclusively Metric at home or work, using a mixture of Metric and Imperial machines (in the case of my Taiwanese FB2 clone assembled from two different sources – both on the same machine !).
My measuring stuff is also a mixture of the two units, though I find Imperial mics easier to read than Metric (I find I can “loose” half a millimetre too easily on the Metric mics).
Any Imperial dimensioned jobs that come in to work are all re-dimensioned Metric – although all the CNC machines can be set & programmed Imperial, fewer mistakes are made if everything is made in the same units. Half of the operators are Polish/ Slovakian – Imperial confuses the heck out of them !
The “40 thou to a millimetre” approximation works well to get close & a Poundshop large digit calculator stuck to the cupboard over the Super7 does near-instant accurate conversions as required. Somewhat bizarrely, I tend to think in millimeters down to 1mm, but find it easier to “visualise” sub-millimetre increments in “thou” !
Nigel B.
