Imperial acme threaded rod
Home Forums Materials Imperial acme threaded rod
Viewing 25 posts - 1 through 25 (of 26 total)
  • #352613
    sean logie
      @seanlogie69385
      Struggling to find myself imperial 1/2″ 10 single start threaded rod/leadscrew for my crosslide . Anyone have any ideas .
      Sean
      sean logie
        @seanlogie69385
        #352615
        jimmy b
          @jimmyb
          Maybe some use?
          #352618
            I was about to suggest Marchantdice … but an internet search suggests that they might have disappeared.
            Jimmy's link looks useful.
            John Haine
              @johnhaine32865
              Zapp Automation?
              #352622
                Posted by John Haine on 03/05/2018 10:58:21:
                Zapp Automation?
                They have trapezoidal … but a search for ACME brings only one result; and I'm pretty sure that's wrong.
                https://www.zappautomation.co.uk/catalogsearch/result/?q=+ACME
                [the spec-sheet appears to show it having a metric screw]
                Edited By Michael Gilligan on 03/05/2018 11:07:09
                #352625
                sean logie
                  @seanlogie69385
                  There’s a lot of suppliers most are metric unfortunately 🤔
                  Sean
                  #352629
                  Ex contributor
                    @mgnbuk
                    Abbsac still list this as a "legacy product" **LINK**
                    Might be worth a call ?
                    Nigel B
                    #352631
                      Posted by sean logie on 03/05/2018 11:22:29:
                      There's a lot of suppliers most are metric unfortunately 🤔
                      Hence the usefulness of jimmy's link
                      The USA might be the only place to buy ACME from stock.
                      Edit: posted before I saw Nigel's comment.
                      Edited By Michael Gilligan on 03/05/2018 11:52:20
                      #352633
                      sean logie
                        @seanlogie69385
                        Yeh think your right michaelG
                        Sean
                        #352636
                        sean logie
                          @seanlogie69385
                          Jimmy b , $147 shipping 🤥🤔🤣.
                          Sean
                          #352648
                          jimmy b
                            @jimmyb
                            Oh!
                            At least you can get it!
                            I once ordered some BSW threaded rod, I didn't ask the price, as I'd had loads of metric stuff costing very little. I think it cost £20….lesson learned
                            Jim
                            #352652
                            Brian H
                              @brianh50089
                              I needed some 1/4" Acme threaded rod and could only get it from USA. Even with the postage it wasn't too expensive.
                              #352655
                              pgk pgk
                                @pgkpgk17461
                                If you can find a us contact to buy and post then mcmaster carr stock acme rod
                                https://www.mcmaster.com/#threaded-rods/=1cohssg
                                #352663
                                mark costello 1
                                  @markcostello1
                                  If You need help, I will.
                                  #352677
                                  Ex contributor
                                    @mgnbuk
                                    If Abssac can't supply, this company **LINK**
                                    were recommended by John Stevenson when this topic was discussed some time ago on this forum. If you go the download page, the standatrd screw products .pdf lists 1/2" 10 tpi LH and RH as stock products.
                                    Nigel B.
                                    Edited By mgnbuk on 03/05/2018 16:09:56
                                    #352679
                                    Robbo
                                      @robbo
                                      Posted by mgnbuk on 03/05/2018 16:09:36:
                                      Nigel B.
                                      I have had acme feed nuts from Kingston, excellent products. Have recommended them on previous threads. Only problem with threaded rod is their minimum length is 3 feet. sad Another link **LINK**
                                      Edited By Robbo on 03/05/2018 16:29:17
                                      #352703
                                      Brian Wood
                                        @brianwood45127
                                        SEan,
                                        I have found another contact for KIngston above sales@kingston-engineering.co.uk
                                        they claim to supply ACME in many forms
                                        #352704
                                          HPC do it as well as nuts both left and right hand
                                          #352706
                                            Posted by JasonB on 03/05/2018 18:52:46:
                                            Dontcha just love it !!
                                            Genuine ACME thread-form, with lead & straightness toleranced in Metric.
                                            Edited By Michael Gilligan on 03/05/2018 18:59:57
                                            #352886
                                            sean logie
                                              @seanlogie69385
                                              Has anyone tried using McMaster Carr in the states . I did a dummy run on an order to find out shipping costs. When I placed the order it said shipping cost and taxes would be added ,maybe I'm missing something but it didn't show the final combined price ,needless to say I immediately stopped the order . Shame because the price was what I was willing to pay sad.
                                              Sean
                                              #352887
                                                By the time they had added taxes and shipping there end and you then add import duty, VAT and fee this end you will probably find HPC or one of the other UK sources cheaper
                                                #397277
                                                Paul Appleton 1
                                                  @paulappleton1
                                                  Mcmaster-Carr will no longer accept orders from the UK. Try finding a LH Acme 5/8×10 tpi leadscrew and nut in Europe!! The old Colchester lathe I have originally has a 5/8×5 TPI thread on the crosslide. This is not even mentioned in most data books. By replacing with a 10TPI I would have had a direct read dial. Wow! how 'modern' is that?
                                                  Kingston Engineering can supply 5/8x 8 LH acme screw and nut 'off the shelf' for around £50 total. But of course I then have to make a new indexing dial.
                                                  I realise that the auto feed rates would be affected by doing a conversion, but thats not really a biggy for me.
                                                  BR, Paul
                                                  #397303
                                                  Dave Halford
                                                    @davehalford22513
                                                    Posted by Paul Appleton 1 on 21/02/2019 08:15:34:
                                                    BR, Paul
                                                    Paul, Whats wrong with using HPC? https://www.hpcgears.com/pdf_c33/2.8-2.9.pdf
                                                    Edited By Dave Halford on 21/02/2019 11:53:34
                                                    #397335
                                                    Pete Rimmer
                                                      @peterimmer30576
                                                      BR, Paul
                                                      The reason is that it's a 10tpi pitch .200" lead 2-start thread.
                                                    Home Forums Materials Topics
