I,m new
I,m new
  • #451646
    Paul Ford 1
      @paulford1
      Hi all,
      I am new to all this and need some advice.
      I bought my first lathe, an old Union Gap bed that I have never really used much, it came with no tooling and I didn't have a clue.
      With where I work now I am feeling the need for a lathe for making small one off parts and managed to find a small Granville lathe with loads of tooling and accessories.
      My problem being it has the motor frame missing, looking around I see that it should have a layshaft with a triple pulley for the lathe and a large pulley drives by the motor.
      Does anyone have any idea of the ideal size pulleys to use as I will need to make this item because I cannot find anything for sale.
      Thanks in advance Paul
      Paul Ford 1
        @paulford1
        Motor frame and layshaft missing
        #451655
        Brian H
          @brianh50089
          Hello Paul and welcome.
          This may help a bit.
          http://www.lathes.co.uk/granville/index.html
          Edited By Brian H on 11/02/2020 07:27:26
          #451704
          Dave Halford
            @davehalford22513
            Hi Paul,
            The layshaft triple mirrors the headstock pulley to keep that belt the same length.
            The layshaft input pulley on my old T&LM was 12" the motor pulley was 2" slowest speed was around 100rpm. A 4" motor pulley proved too fast for the plain bearings.
            All picador A section parts parts.
            #451705
            David George 1
              @davidgeorge1
              I have never heard of a Granville lathe so had a look and they were made in Sutton in Ashfield just down the road from where I live.
              David
              #451707
              John Hinkley
                @johnhinkley26699
                Paul,
                Brian has given you the best link available to try to establish which lathe is in question. The fact that it would come with tooling and accessories has to be a big plus-point in deciding whether to purchase or not. From a brief look at the lathes.co.uk site link, it would appear that the lathes are all roughly Myford size and I would be very surprised if you couldn't utilise a secondhand Myford layshaft, with or without the clutch, without too much jiggery-pokery.
                I am assuming that you are UK based as that will make a difference to the validity of the advice you receive in terms of availability of suitable parts. I surmise that original replacement parts will be extremely difficult to source, if not impossible, as you appear to have found.
                The drive system used in the designs shown on Tony Griffith's site were very common and similar for a large number of lathes of that era and I'm sure that a lot of them could be modified to fit. As Dave Halford has said, keep the drive and driven pulley sizes mirrored for the reason stated and use the motor to layshaft pulleys to obtain an acceptable speed range overall.
                Good luck and let us know how you get on.
                Howard Lewis
                  @howardlewis46836
                  Assuming that you are UK based, with 50 Hz mains, a four pole motor will run at about 1470 rpm.
                  You can use this figure to calculate the size of pulleys to provide a minimum sped of 100 rpm or less.
                  The pulleys on the Lathe will give you the sizes for the Layshaft. If you wish, you could have two cone pulleys on the layshaft. This would avoid the problem of having to move one belt under the other when setting certain speeds.
                  HTH
                  #451723
                  Dave Halford
                    @davehalford22513
                    Ye Olde layshaft, just a straight bar that happens to fit ball races in the wooden blocks and the pullies
                    Edited By Dave Halford on 11/02/2020 13:13:35
                    #451752
                    Howard Lewis
                      @howardlewis46836
                      For layshaft bearings you have a choice between plain bearings, ( Brass or Phosphor Bronze) with regular oil lubrication, or sealed for life ball races.
                      With a three step pulley set for the layshaft to Lathe, and another for the motor to layshaft, you would have nine speeds available.
                      #451760
                      David George 1
                        @davidgeorge1
                        Dave Halford you have left the chuck key in the chuck! Here is picture of my Drummond M Type it nay give you an idea or two.controle switches.jpg
                        David
