some advice from the petrol heads please (not to exclude wise non-petrol heads)
after a few weeks I have finally got my Jan Ridders SABINE 2 stroke to run. I have issues with it which I think are related to the ignition circuit, after getting better results from changing the battery upwards a couple of times. I am now using a 12v 15AH dry fit battery with a 12v Lucas coil and a condenser from a mini, which I don't know the value of and a v3 micro switch as a contact breaker.
with a fully charged battery the engine will run for about a minute and the fade out. The terminal voltage falls to @ 11.9v under load.
i would welcome some advice on the combination of the components. Is the coils too large for the battery?
thanks in advance
Bob..
