Posted by Martin Dilly 2 on 09/01/2020 10:44:23:
Is there any way, apart from paying a fortune for metallurgical analysis, that I can make an educated guess about what I've got? It produces more of a clunk than a ping when you drop a piece!
It's unlikely to be Titanium, Magnesium, or Zinc. Aluminium reacts with Sodium Hydroxide (Caustic Soda) to make Hydrogen. Done in a test tube the hydrogen can be ignited with a characteristic 'pop' explosion. If you have a drop of Mercury, Aluminium is eaten by it, producing a characteristic efflorescence.
These simple chemical tests will only confirm it's an Aluminium Alloy. You could get close to identifying which particular alloy (and there are dozens of them) by measuring the sheet's density. Done by comparing the sheet's accurate weight with the weight or volume of water displaced when immersed. See 'Eureka'.
Seems an awful fuss for an ebay sale though. I don't suppose anyone in Aerospace will buy it!. If it were mine I'd just describe it as Aluminium sheet surplus from signage. If confident about telling the difference I' might go so far as to describe it as soft or hard. (This is easy to do by comparison, tricky if you only have experience of one type!) You can say what you like as long as the description isn't misleading.
