Posted by Tim Stevens on 12/04/2023 17:27:47:
The two cones may well serve as formers for sheet metal bending or forming. Or as parts of a spinning lathe (no, not a lathe which is spinning, but for the operation called metal spinning where you start with a flat circle of sheet and press the metal as the former spins, in stages, to produc cups, headlamp reflectors, etc). The thing with the big tommy-bar looks like a spanner to turn, or hold, a splined shaft while you do things to it, or perhaps with it. It might be used to control the chuck which holds one or other of the conical tools.
Was anything else included in the same job-lot?
Cheers, Tim
nothing exept some chipped end mills – those cones are about 1 1/2" long. I thought they could be some kind of hole centre finders. Came with vertical milling machine.
Edited By Dan Shilling on 12/04/2023 19:04:29
Edited By Dan Shilling on 12/04/2023 19:06:46
