Identify imperial bolt size
Home Forums General Questions Identify imperial bolt size
Viewing 25 posts - 1 through 25 (of 30 total)
  • #649874
    Margaret Trelawny
      @margarettrelawny34058
      Hi
      I need help identifying a thread size – created in the 1960s in England. Machined into brass – we don’t want to drill/retap the piece.
      An M3 bolt is slightly too small, an M4 too big. Using an online converter we purchased 6-32 UNC and 4-40 UNC but neither fit.
      Appreciate it’s not much to go on but any help would be gratefully received.
      thank you
      Margaret
      Margaret Trelawny
        Vintage bolt thread
        #649912
          It could well be a BA thread, if you can say what the item is then that would help.
          5BA is just a little larger than M3 at about 3.2mm but was not a preferred commercial size though often used for models
          4BA would fall mid way between M3 and M4 as it is approx 3.5mm diameter and was one of the preferred sizes in the BA range
          #649913
          Kiwi Bloke
            @kiwibloke62605
            Jason beat me. Agreed, 4BA likely. BA threads were used widely in UK, especially in electrical apparatus, millions of holes tapped in brass to receive them.
            #649914
              [ as usual ] Jason probably has the answer, Margaret
              As a very helpful quick check, you might try screwing something like a wooden barbecue-skewer gently into the tapped hole. … when unscrewed this should reveal an impression of the thread, the pitch of which can then be measured.
              Martin Connelly
                @martinconnelly55370
                I have to object to the idea that something from the 60s is vintage wink
                Martin C
                #649921
                Nick Wheeler
                  @nickwheeler
                  Posted by Martin Connelly on 25/06/2023 07:59:38:
                  Martin C
                  You're not American.
                  #649924
                  Howard Lewis
                    @howardlewis46836
                    If not a BA size (Pity we have no dimensions for the part that scrrews in ) might it be 5/32 BSW?
                    Same size as used by Meccano
                    0156" OD, (3.968 mm. if you must )
                    #649926
                    Margaret Trelawny
                      Thank you everyone.
                      the part is a puppet Undercontrol mechanism as used in tv shows and films of the era.
                      #649928
                      noel shelley
                        @noelshelley55608
                        Like the others,as not metric or UN I would go for 4BA. At 3.97mm 5/32w is likely to be tooo big, and rather coarse. Good luck. Noel.
                        #649930
                        Margaret Trelawny
                          Thanks Noel. I’ll order some 4BA and keep you all posted. Appreciate everyone’s help very much.
                          Margaret
                          #649931
                            Posted by Margaret Trelawny on 25/06/2023 09:26:52:
                            I'd bet the farm on it being a BA thread – extremely common for small fasteners, especially telecomms, electromechanical, instruments, electrical etc. Highly likely in a British made mechanism of that era. Although supplanted by metric in new products, BA is still widely available; the internet is your friend!
                            noel shelley
                              @noelshelley55608
                              Margaret, The only thing if ordering in is to specify the head type. Hexagon, cheese head, countersunk, slot or allen key, socket head. These are the common types, then there is the length. Best wishes Noel.
                              #649939
                              Margaret Trelawny
                                4BA dome slot heads ordered. Finger’s crossed🤞 thanks everyone 🙏🏻
                                #649949
                                Ian Parkin
                                  @ianparkin39383
                                  Could be worth trying m 3.5
                                  lots of those in a UK home remove a screw from a switch plate or socket just to see if it fits
                                  m 3.5 is about 42 tpi
                                  #649991
                                  old mart
                                    @oldmart
                                    60's is vintage, but not as vintage as me. I'm in my 9th decade when you count up the decades starting with 1949. Only the other day, I tapped two holes for 4BA screws as there were plenty of countersunk ones within easy reach. And they are in the new Atlas 12 x 24 cross slide which has now got threads of 1/2UNF, 4, 5 and 6mm plus the 4BA's in it.
                                    Edited By old mart on 25/06/2023 19:53:31
                                    #650021
                                    not done it yet
                                      @notdoneityet
                                      Posted by old mart on 25/06/2023 19:50:20:
                                      The item may not be classed as ‘vintage’ but the thread may well be! How old might a vintage wine be? Classic cars are generally over 25 years and veteran cars are pre-1930?
                                      #650023
                                      Robert Atkinson 2
                                        @robertatkinson2
                                        M3.5 is interchangable with 4BA. This non-preferred size is used in the UK for commonality with older electrical fittings. Availble from any hardware or electrical supplier.
                                        Robert.
                                        #650110
                                        Chris Pearson 1
                                          @chrispearson1
                                          Posted by Robert Atkinson 2 on 26/06/2023 08:47:11:
                                          Robert.
                                          Ouch! The pitch and diameter may be similar, but the angle of the thread is completely different.
                                          #650113
                                            Also far less choice of heads and material in M3.5
                                            Pitch is not that similar, depends a bit on how long the female thread is, might be OK on an thin electrical box tab to mix the two but with M3.5 having a tpi of 42.3 (0.6mm) and BA one of 38.5 things will soon get tight
                                            Edited By JasonB on 27/06/2023 07:14:29
                                            #650118
                                            Nicholas Farr
                                              @nicholasfarr14254
                                              Hi, 4 BA pitch = 0.66mm, M3.5 pitch = 0.6mm, so in ten threads, the 4 BA will be 0.6mm longer. I've just tried a 4 BA into an electrical box, and without forcing it with a screw driver, it won't even poke through the 2mm thick lug, likewise the threads of the M3.5 screw won't show through a standard 4 BA nut, so I don't class them as compatible.
                                              Regards Nick.
                                              Edited By Nicholas Farr on 27/06/2023 07:49:11
                                              #650135
                                              Howard Lewis
                                                @howardlewis46836
                                                Metric and BA threads should not be interchangeable.
                                                Metric are 60 degree form while BA are 47.5 degrees, so there is bound to be a mismatch of form, as well as pitch.
                                                #650136
                                                Macolm
                                                  @macolm
                                                  If you need to substitute M3.5 screws for 4BA in old electrical boxes, you can buy "rethreaders" from Screwfix and Toolstation amoung others. The resultant fit is not particularly good, and best not to over tighten!
                                                  #650160
                                                  File Handle
                                                    @filehandle
                                                    I also tried a 4BA nut on a 3.5mm electrical screw. Jams after a few turns, but I wasn't surprised as they are dissimilar. I wonder if M3.5 are being sold as 4BA causing confusion.
                                                    #650168
                                                    john halfpenny
                                                      @johnhalfpenny52803
                                                      I keep my metric and imperial electrical socket screws in separate tins since first encountering this 25 years ago. They are not interchangeable.
