+1 for the idea of overheating to the extent that the level goes up into a larger diameter part of the glass tube, and I also see the risks.
I note that the OP's thermometer reads 0-50 degrees. If the thermometer is put in a freezer, in a vertical position, will the alcohol level drop into the bulb, and then expand in an unbroken column when the thermometer is returned to room temperature? Don't leave it in too long, you don't want the alcohol to freeze!
Rod
