I always make my rings the same diameter as the bore. I then split them, emery the gap, to give the correct ring gap I then wedge open the ring and heat to 500 degrees Centigrade. This gives the rings the necessary spring to push against the cylinder bore. Otherwise you don't get compression and one needs an electric finger to start the blighter. The performance is very poor as well, as the ring is effectively worn out.
Now I am talking about racing .60 cubic inch engines. I have NO experience of any other engines! There are some weird ideas that the compressed gas gets to the back of the ring and expands them. There are other complaints that the rings made as I explained above will have serious friction problems and thus give a reduced power output. NONE of these gripes are true, in the size of engine that I am talking of.
Other styles of engine and sizes may give these statements some credence. But in these 10 cc racing engines, they don't hold. So it depends on what engines you are talking about. As far as the ring width to depth is concerned. I simply use the original manufacturers sizes. Unless I have to make new pistons and then I am not too fussy about dimensions.
There is a lot more to getting rings to work than stated above. I usually hone cylinders to ensure circularity. I also use fine diamond paste to bed down the assembly. The latter improves some aspects of the engine and it can be run at full power straight away without "running in" (I use cast iron pistons for this and then swap to aluminium pistons, for obvious reasons.
Andrew.
