I need custard.
I need custard.
Home Forums The Tea Room I need custard.
Viewing 6 posts - 51 through 56 (of 56 total)
  • #656847
    Mike Poole
      @mikepoole82104
      Posted by Howard Lewis on 17/08/2023 01:58:59:
      Even wire wool will burn!
      When my parents were having central heating installed the plumber had a Ford Thames van, he kept a large pack of wire wool behind the drivers seat but unfortunately the Thames battery is also located there, inevitably the wire wool met the battery and there was lots of smoke and glowing wire wool. For a young lad it was quite exciting but I think the Norman the plumber was less impressed.
      DMB
        @dmb
        So that's the solution to constipation – a custard powder blast! Problem would be placement in the right area.
        I'll leave now, ha, ha.
        #656862
        roy entwistle
          @royentwistle24699
          I prefer carnation condensed milk.
          ( I'll hide now )
          Roy
          #656866
          File Handle
            @filehandle
            When I was a science teacher, I would regularly use any excuse to explode flour. A good way to demonstrate that food provides energy. There was a knack to getting it to work well. Would blow the lid of a large tin can.
            #656916
            mark costello 1
              @markcostello1
              I cannot understand how rock dust explodes, but it must. Starting fluid detonates also. Here's how I know. Taken about 1 minute after the event. Whipped the starter cord violently back and hit My hand in the process.img_20220528_232537_mp.jpg
              #656935
              Mark Rand
                @markrand96270
                Ether, if used in the starting fluid, will ignite with a 6:1 compression ratio without aid of a spark. So if you're using it with a higher compression engine, it can easily pre-ignite
