I need custard.
I need custard.
Home Forums The Tea Room I need custard.
Viewing 25 posts - 26 through 50 (of 56 total)
  • #656494
    Mike Poole
      @mikepoole82104
      **LINK*
      https://youtu.be/Iz9KnPZWOgs
      If you want to fill your swimming pool with custard you can walk on it.
      Edited By Mike Poole on 14/08/2023 10:34:28
      Edited By Mike Poole on 14/08/2023 10:35:27
      Ex contributor
        @mgnbuk
        I don't make custard very often – hate cleaning saucepan
        Make it in a Pyrex jug in the microwave – no pan to clean.
        Nigel B.
        #656505
        GordonH
          @gordonh
          Posted by Sam Stones on 14/08/2023 04:58:54:
          So where, in the kitchen, could you easily demonstrate Bernoulli?
          Sam smile d
          Chilling out in Melbourne
          Just let a container with a rounded lip and a gentle supply of water overflow. Looking from the side, a " Bernoulli Line " can be seen where the surface of the water dips as it accelerates over the curved lip and the acceleration causes a local pressure drop at the surface. Water flowing over a wier is a good example.
          I'd rather be chilling out in Melbourne than here in Solihull!
          Edited for spelling correction
          Edited By GordonH on 14/08/2023 11:56:51
          #656516
          Clive Hartland
            @clivehartland94829
            I can remeber at some time in the South of London an explosion in a custard factory where dust blown through ducting exploded. You can see the place as you leave London on the southern line.
            #656593
            Nick Clarke 3
              @nickclarke3
              Posted by Clive Hartland on 14/08/2023 13:34:42:
              Used to demonstrate that in school science lessons with a 2.5l paint tin (new and bought empty) and a bunsen burner. blowing into a bit of rubber tube caused custard powder in the tin to be sprayed about in the tin where the flame from the bunsen blew the lid off with a satisfying bang!
              While the experiment was supposed to show that you need to expose a large surface area and not just a heap of custard powder to burn it was not a very successful experiment as pupils didn't really see the point – and after one colleague showed you could get the lid of the tin to blow off with no bunsen or custard, just a hard blow we stopped doing the experiment.
              Edited By Nick Clarke 3 on 15/08/2023 08:41:26
              #656600
              Nealeb
                @nealeb
                All of this talk of explosive custard is a wicked urban myth spread by militant "ice cream at all costs" North American dessert eaters. I can confidently say that in all my years of making custard, I have never had a pan of it do so much as burst into flames even when cooking on a gas ring.
                Now, the old "treacle tin" experiment in the chemistry lab was quite a different story…
                #656601
                duncan webster 1
                  @duncanwebster1
                  A few years ago several workers were killed when a factory producing wood flour exploded, and lots of coal mine explosions were made a lot worse by coal dust, the dust being made airborne by an initial fired damp explosion. I've seen reports of grain silos going off as well, down to dust created by conveyors
                  #656603
                  Nick Wheeler
                    @nickwheeler
                    Posted by Neil Wyatt on 14/08/2023 10:27:14:
                    Thanks for brightening up my morning …
                    And mine, although this thread reads as if many of the posters have been imbibing fermented custard…
                    #656606
                    Bazyle
                      @bazyle
                      Custard powder with very little water was also used at school to demonstrate a thixotropic paste.
                      #656611
                      Mick B1
                        @mickb1
                        Posted by duncan webster on 15/08/2023 09:47:46:
                        In the early '70s I was labouring in the cutting room at Players' factory, moving bins of shredded tobacco leaf to the driers. There was usually a haze of tobacco dust hanging in the air. Dry tobacco burning as readily as it does, how it never blew up I don't know. Nor how I escaped any of the various lung diseases.
                        #656622
                        Nicholas Farr
                          @nicholasfarr14254
                          Posted by Nealeb on 15/08/2023 09:27:40:
                          Hi, custard powder will explode, I saw a film where it happened in a custard factory, don't know if it was the one that Clive Hartland has mentioned though. You can't just light a fuse that is inserted into a pile of custard though. This type of explosion is known as a dust cloud explosion, where there is a large cloud of enough dust that is airborne inside a building for instance, and the smallest spark or flame can set it of. There are many products that are able to produce airborne dust, that this can happen too, that you wouldn't think would exploded in this way, which is one reason why good and efficient dust extraction should be used in these sort of areas. I knew one man that was a contractor in my old job at times, who was killed by a dust explosion at a different company he was doing work for, when a spark entered a silo that was being filled at the time, which produced dust to form in the top of it, can't remember the product, but not something that you would have thought would explode.
                          Regards Nick.
                          #656633
                          lee webster
                            @leewebster72680
                            I am unfamiliar with the explosive capabilities of custard in any form. I am however reminded of the demise of the treacle mines in my old home town of Hemel (treacle bumstead) Hempstead. It was in the mid 1800s that the largest treacle mine in Hemel, if not in England, suffered a devastating explosion that caused many injuries. It couldn't be determined if the explosion was caused by the treacle fumes being ignited by a candle, or by a spark by a steel tipped treacle drill. The mining of treacle in England was determined to be too dangerous. Ever since then we have imported our treacle.
                            Only the rich could afford mined treacle, the working classes had to make do with artificial treacle.
                            #656637
                            Journeyman
                              @journeyman
                              Reading too much Terry Pratchett perchance. See The Fifth Elephant to explain the formation of the treacle minewink
                              Speedy Builder5
                                @speedybuilder5
                                treacle mines – Chobham Surrey (goes nicely with custard.
                                Treacle Mine
                                #656647
                                duncan webster 1
                                  @duncanwebster1
                                  It is well known that there were treacle mines in Pudsey, between Leeds and Bradford. When the Cornish tin mines started to go out of business, the Pudsey treacle barons bought one and had it shipped up north so they could dog out the treacle ready tinned. As Pudsey lies in a dip between it's 2 larger neighbours it suffered from chronic smoke problems. The ducks evolved to fly backwards to keep the soot out of their eyes.
                                  Other local industries included the manufacture of whim-whams, 'for t' ducks to peek on'. I've no idea what it means either!
                                  #656648
                                  duncan webster 1
                                    @duncanwebster1
                                    In the middle ages, "treacle" had medicinal connections, so if something like say calamine was being mined, you had a treacle mine
                                    #656685
                                    Chris Pearson 1
                                      @chrispearson1
                                      I witnessed that in (IIRC) Richmond, Yorks 30-odd years ago. My first thought was that a gas cylinder had gone up in the hardware store, but it was the baker next door. The clue was the loaves strewn amongst the glass splinters in t'middle of the road.
                                      Or was it Ripon: my brain is fading.
                                      Edited By Chris Pearson 1 on 15/08/2023 22:10:21
                                      Edited By Chris Pearson 1 on 15/08/2023 22:10:39
                                      Edited By Chris Pearson 1 on 15/08/2023 22:11:53
                                      #656716
                                      Nealeb
                                        @nealeb
                                        I seem to remember a children's programme on television years back where they demonstrated this powder-based explosion problem by blowing a puff of ordinary cooking flour into a transparent vessel continuing a lit candle. Very much a "don't try this at home" experiment – wonder if that sort of thing would be allowed on television these days?
                                        #656717
                                          Posted by Nealeb on 16/08/2023 08:48:36:
                                          Certainly is. Stephen Fry did the powder explosion on QI. Moving up the scale, Tony Robinson did a series demonstrating the effects of replica WW2 German Bombs on typical British homes. From memory his smallest explosion was 50kg of an un-named High Explosive, distinctly more violent than custard powder! Mythbusters (made in the US where they have more empty space for big bangs), filmed many explosion based myths and realities. Gas igniting inside a Portaloo (don't smoke), up to a cement truck filled with quarry blasting explosive.
                                          Modern TV is increasingly coy about the exact 'how to' details. No desire to make it easy for those who want to cause explosions in crowded public places. All countries have large 'Sh1t for Brains' communities!
                                          david homer
                                            @davidhomer12226
                                            I worked for 30 years at General Foods (Birds Custard and Maxwell House Coffee) in Banbury where we had a dust explosion in the Desserts area 1981 involving one of the Custard plants. I was just coming onto night shift at 9:45 pm and was just in the locker room getting changed when the explosion occurred, the fire alarm was sounding and as maintenance staff we were part of the Fire Team and started off towards the area being announced over the Tannoy system, walking through a fog of cornstarch dust..
                                            For anyone interested the link below is for the Factory inspectors report.
                                            https://archive.org/details/op1275789-1001
                                            David
                                            #656722
                                            david homer
                                              @davidhomer12226
                                              The Explosion Demonstration for new starters at General Foods consisting of a 10" od Steel tube, open top solid bottom, an airline connection towards the bottom, a spark plug at the bottom, connected to an HT transformer with a push button. 1teaspoon of custard powder was placed was in the bottom, a paper diaphragm held over the top with a Jubilee clip. The routine was a short shot of air to get custard powder airborne and then a push of the button for the ignition source and you end up with a small bang and a burst diaphragm.
                                              David
                                              #656723
                                              Ramon Wilson
                                                @ramonwilson3
                                                Posted by david homer on 16/08/2023 10:13:10:
                                                David
                                                Well, there you have it Lee, (see the OP) official confirmation from an inside source wink All you have to do now is find a retail outlet for one.
                                                FWIW I had a decent bowl of the Bird's instant stuff last night poured over some blackberries – lovely smiley
                                                Best – Tug
                                                #656826
                                                Howard Lewis
                                                  @howardlewis46836
                                                  Custard powder, sawdust, and coal dust are all hydrocarbons, so if mixed with oxygen, in the air, or elsewhere, can be combustible. amd so explosive..
                                                  In America at least one railroad company experimented with coal dust as a suitable substitute for coal in a specially built steam loco.
                                                  There have also been esxperiemnts to inject coal dust as a fuel ,for compression ignition engines. (The problem was that the coal dust slurry, being abrasive, shortened the life of the pump and injector components. )
                                                  My future in laws lived in a flat, and the old ladies below would carry coal, up the stairs, dropping coal dust as they went.
                                                  Terrified me, fearing, at least, a fire, if not an explosion, as we all crunched our way upstairs!
                                                  Thankfully, F i L retired and they moved out!
                                                  Even wire wool will burn!
                                                  #656835
                                                  James A
                                                    @jamesalford67616
                                                    I recall a documentary about the fire of London and speculation that it exacerbated by an explosion of flour dust in the Pudding Lane bakery, not just a fire.
                                                    James
                                                    #656846
                                                    Mick B1
                                                      @mickb1
                                                      Try Wikipedia with 'thermobaric weapon'. It's clear that this subject has been well understood by weapons engineers for a long while. Some have suggested it was a coaldust explosion, subsequent to the torpedo, that sank the Lusitania so disastrously in 1915.
                                                      I don't think custard powder is a preferred fuel.
