I may be stupid but
I may be stupid but
Home Forums The Tea Room I may be stupid but
Viewing 25 posts - 1 through 25 (of 55 total)
  • #602847
    Steviegtr
      @steviegtr
      Hi guys. As the description & lots of members on here know i am a bit stupid, Some don't.
      So the question is when i watch youtube video's, lots of tubers when using a 3 jaw chuck. They put in a piece of stock & then tighten the work with the key. Then rotate & tighten again , then rotate another 3rd & again. Why ????. I never do this. I know the chuck is a scroll device so why would i want to rotate & TIGHTEN ALL 3 KEY HOLES.
      So please answer honestly am i stupid or maybe i am missing something. Please correct me if i am wrong.
      Steve.
      Steviegtr
        @steviegtr
        Tightening a 3 jaw chuck.
        #602850
        Nigel Graham 2
          @nigelgraham2
          No you are not stupid. I can't imagine why they do that, either.
          I rarely watch You-Tube videos these days, driven away by the advertising clutter, but I can't say I have noticed that habit. However, it does seem odd.
          Perhaps many of them use a lot of rough old bar or knackered chucks (knackered by rough old bar?) and find, or think they have found, they need use all three pinions to cope.
          Or they have picked up bad habits from each other.
          #602851
          Clive Foster
            @clivefoster55965
            Allegedly this practice reduces run out by helping balance the forces on the scroll so it moves closer to true centre.
            It is said that any wear in the chuck allows the scroll to float slightly off centre causing run out.
            I've never seen any figures of calculated run out associated with any degree of wear so am mor ethan a little skeptical. Maybe if a chuck is well worn.
            A few brief tests showed no sensibly repeatable effects on the three jaws I use. But mine are in decent to very good condition with known history. I suspect supporting the work rather than relying on the lower jaw(s) to lift it onto centre helps control any imbalace. As does nip, rest, final tighten technique rather than simply pulling up in one go.
            Life is too short to do proper, statistically significant tests backed up by wear measurements.
            Any three jaw needing that level of playing to get decently acceptable results is, in my view, only fit for the bin. By its very nature a three jaw is of limited precision. Trying to do better than the concept allows is guilding the lilly in on uncertain terms. I understand the logic of a GripTrue and the various home brew equivalents but the faffing involved in setting up seems a vast waste of effort. Although certain limited circumstances can exploit such it doesn't alter the fact that you are trying to make an unsuitable tool work for the job in question.
            #602855
            John McNamara
              @johnmcnamara74883
              The scroll in a 3 jaw chuck has to have a small amount of lateral clearance within the chuck body or it would seize up. this creates a small and unavoidable radial error that grows as the chuck gets older.
              Try this; put a piece of ground stock in the chuck using one of the tightening points. Mark it with an A using a felt pen. Then check the concentricity of the ground stock with a dial indicator. Note the max high and low amounts and points for A using the felt pen on the chuck body. Now repeat this for the rest of the tightening points.
              You will find that the noted points are not all in the same position. most likely one of the drive points will give the least run out. this is because no scroll chuck is perfect, when you drive the scroll from one point on its side it is pushed laterally by the angled drive gear inside the chuck. this may increase or decrease the total error in the system.
              Some machinists take advantage of this phenomenon and mark the drive point on their chuck that gives the least run-out error.
              Unfortunately there are other errors in the chuck mechanism the scroll itself and the teeth on the back of the jaws also are not perfect; different diameter workpieces may give differing results.
              For normal 3 jaw chuck work I do not worry about small errors, however if doing a long run of the same part that requires high precision it may help to find the best drive point to use to reduce error.
              All this can be avoided by using a 4 jaw chuck and a dial indicator however the three jaw is a great time saver.
              Edited By John McNamara on 24/06/2022 00:51:06
              #602856
              Steviegtr
                @steviegtr
                Well that is food for thought guys. I do have the Griptru & have never had any issues by just tightening 1 keyhole.
                Steve.
                #602861
                Howard Lewis
                  @howardlewis46836
                  Being of the "Hammer and chisel" fraternity, I never , or very rarely bother.
                  Theoretically, tightening all three jaws should be better since it loads the scroll in three places, (But tightening one jaw, will load the scroll via the other two anyway. )
                  If you want better concentricity, use a four jaw and clock the work. In that way you should be able to get better than 0.012 mm run out. Even less if you are prepared to invest the time and effort to do better than that.
                  #602869
                  oldvelo
                    @oldvelo
                    An old mentor of mine in the now distant past "always tighten all four holes in a three jaw chuck". If one to tighten suits you that's fine. But why is there movement at each hole tightened and very hard to undo.
                    Same applies to a Drill chuck it settles the load evenly on the jaws.
                    #602870
                    Bountyboy
                      @bountyboy
                      Hi Steve,
                      I agree with Nigel, you’re not stupid. Anyway I thought you had an Albrecht chuck, the Rolls Royce of keyless chucks. 😀
                      #602876
                      Speedy Builder5
                        @speedybuilder5
                        If I am going to use bar stock and part off the turned piece, I tighten all 3 jaws and there is usually some movement on each position – so something moves!
                        Bob
                        #602877
                        Hopper
                          @hopper
                          Good quality chucks such as the old Crowns and Burnerds etc often had a "0" or other reference mark stamped on the chuck body next to the chuck key hole that was used in the factory to tighten the jaws for final grinding or testing. So they seemed to think at the factory that which keyhole you used could influence runout. The "tighten all four holes" regime seems to have come about more to ensure a tight grip with worn chucks (which begins the first time you use it) and does seem to work, and to help minimise runout in my experience. Ditto drill chucks. Or you could do like all the machinists in those YouTube videos from Pakistan Truckers etc whose preference is a good three-foot length of pipe over the chuck key handle. Seems to be universal over there. And it seems to work for them. I would hesitate to recommend it though.
                          #602882
                          James A
                            @jamesalford67616
                            My grandad, who was a professional engineer working from the 1920s onwards, used to drum into me the need to use all three key holes on a chuck. Why, I never knew, but presumably it was established practice at one time.
                            James.
                            #602883
                            Oldiron
                              @oldiron
                              Posted by Bountyboy on 24/06/2022 06:43:40:
                              Hi Steve,
                              I though we were talking 3 jaw lathe chucks here or am I stupid ?
                              regards
                              #602884
                              Rex Hanman
                                @rexhanman57403
                                If one hole is adequate, why would the manufacturer add others? There must be an advantage other than convenience.
                                #602885
                                AdrianR
                                  @adrianr18614
                                  If you think about the forces on the scroll, it is better to tighten all three, ideally, you would turn all of them at the same time.
                                  When you turn one you are applying a tangential force to the scroll, This will rotate and move the scroll laterally, hence the off-centre tightening. Also, there is friction between the scroll, body and jaws which will resist the rotation of the scroll so it can get wedged in a non-ideal position.
                                  Tightening all three wiggles the scroll around so improves the tightening.
                                  Yes, you can get a chuck tight on one point, but I find you can always get a little more if you use all three points.
                                  #602886
                                  Nick Wheeler
                                    @nickwheeler
                                    Posted by James Alford on 24/06/2022 07:44:20:
                                    Mine said the same. It does seem to make the chuck grip a drill better.
                                    So I tighten all three jaws on the lathe chuck when I think the part would benefit from more security – like roughing out a fresh piece of stock. I don't do it on fragile, already machined parts.
                                    #602888
                                    Mike Hurley
                                      @mikehurley60381
                                      Posted by Rex Hanman on 24/06/2022 08:02:16:
                                      My thoughts exactly!
                                      #602889
                                      roy entwistle
                                        @royentwistle24699
                                        I have always used all three holes on a three jaw. and on a drill chuck. It was what we were taught at Tech. in the 40s
                                        Roy
                                        #602891
                                        Hopper
                                          @hopper
                                          Posted by Mike Hurley on 24/06/2022 09:15:10:
                                          As the bishop said to the actress. wink
                                          #602893
                                          JohnF
                                            @johnf59703
                                            James.
                                            Exactly James, I have been doing this from 1960 — same reason, my mentors instruction — several different ones and it does work ! you get a less runout by progressivily tightening the chuck working around the holes, I also always start at the same hole every time.
                                            Mike Poole
                                              @mikepoole82104
                                              I bet if chucks had a single hole then there would be a thread about what a great idea it would be to have 3 holes so there was always one on top for immediate use.smiley On a larger geared head lathe it could be something of an effort to rotate the chuck, I seem to remember setting one of the gearbox levers to a halfway position to effectively disengage the gearbox when setting up a 4 jaw job.
                                              Edited By Mike Poole on 24/06/2022 09:44:30
                                              #602897
                                                Posted by AdrianR on 24/06/2022 08:34:18:
                                                Exactly.
                                                Even new chucks are imperfect mechanically and the fit gets worse with wear. Although the scroll mostly rotates, it also moves slightly sideways and perhaps tilts as well. Although the unwanted movement is tiny, it's enough to stop the jaws from fully tightening. Turning the adjusters in sequence tends to release jambing due to non-rotary movement, and allows the jaws to tighten a little more. Three is enough.
                                                Worth doing because the purpose of a chuck is to grip work and it needs all the help it can get from the operator! Finking it's not necessary is a poor substitute for not just doing it – only takes a moment.
                                                Quite a good example of a workshop subtlety that a maker of internet videos might inadvertently spread as a bad practice. Very easy for newcomers to copy the well-presented misunderstandings of an inexperienced machinist who enjoys making videos. Experienced machinists often develop inadvertent bad-habits too. The problem is usually failing to have work peer reviewed by a few qualified critics before publication. Write 1000 times before publishing anything: "Individuals, especially me, are really, really bad at spotting their own mistakes.'
                                                Mick B1
                                                  @mickb1
                                                  Posted by SillyOldDuffer on 24/06/2022 09:55:53:
                                                  Exactly.
                                                  Yes, all true, but – maddeningly – sellers only issue one key, usually only one or at most two key pinions are accessible from any single position, and I've never met anybody with enough arms…
                                                  wink
                                                  Certainly if I'm trying for concentricity with the gripped diameter, I've found I get the best results (about 2 or 3 tenths TIR) by tightening all 3 pinions – but it's not common to need that, so in most cases I won't bother.
                                                  But even if I have to play about with a few attempts, clocking the concentricity as I go, it's generally still a helluva lot quicker than swapping to a 4-jaw independent chuck. I generally use those for eccentrics or components unsuitable for 3-jaw grip. Because 3-jaws seem so much better today than they were when I started turning, I find myself unwilling to disturb it without very good reason.
                                                  #602911
                                                  Steviegtr
                                                    @steviegtr
                                                    Posted by Oldiron on 24/06/2022 07:51:14:
                                                    Hi Steve,
                                                    regards
                                                    No old iron i was meaning the main lathe chuck , not a tailstock drill chuck.
                                                    Steve.
                                                    #602912
                                                    Dalboy
                                                      @dalboy
                                                      I also was taught to use all three positions when tightening a drill chuck and have carried that over to my lathe chucks.
                                                      I find it does hold better than just tightening with the one point.
                                                      Have you ever noticed that when tightening in a single hole that when undoing it you will find that one will always undo easier than the other two positions.
