I just don’t beliieeve it..
Home Forums The Tea Room I just don’t beliieeve it..
  • #572308
    pgk pgk
      @pgkpgk17461
      I had need to cover a ceiling stain and thought easiest would be a coat of oily white gloss it won’t bleed through, then emulsion later.
      I had a tin o Dulux Weathershield external 6yr brilliant white gloss. New and unopened but likely bought a few years ago 'cos I don't remember when, why or where.
      I opened it up… Burgundy all the way to the bottom..
      pgk
      pgk pgk
        @pgkpgk17461
        ..paint but not a paint question
        #572311
        HOWARDT
          @howardt
          Better to use one of the stain blockers, even gloss paint will stain through eventually. I have a small spray can and use it occasionally.
          #572316
          pgk pgk
            @pgkpgk17461
            'Twas a case of what was on hand – and that my reading reviews on a few varieties of stain blockers had many disappointments. Recommendations? Spraying would be a pain in this case with lost of masking between roof light and wall window
            pgk
            #572318
            john fletcher 1
              @johnfletcher1
              Several years ag I covered a creosote stain with several application of Aluminium metal paint, not the wood primer, still OK. John
              #572321
              Phil Whitley
                @philwhitley94135
                White pigment is usually titanium dioxide which is heavy, and so settles out, but if you have stirred it thoroughly right to the bottom my only suggestion is a new fashion trend for burgundy gloss ceilings!
                I'll get me coat!
                Phil
                #572324
                the artfull-codger
                  @theartfull-codger
                  I used zinsser bullseye 123 on a stain on our ceiling & it cured it ok
                  #572326
                    Zinsser for me but I tend to use "Cover Stain"
                    #572340
                    Rick Hann
                      @rickhann79631
                      Prime with white lacquer and Bob"s your uncle!
                      Rick
