Evening all, hope well and safe.
I need to drill a straight'ish hole In some square 6082, it will be 180mm long with a finished diameter 19mm for half the depth and 16mm for the other half. Once I have my initial hole I can bore from either end, I'm guessing with a boring bar?
Anyway I have two approaches for the I initial hole but Im not sure which to pursue. Max I have drill size is 14mm in jobber and extra long with a few other sizes the same. Using the 7×12 Clarke I can either drill half way using a cats cradle to support the stock then reverse using a M2 jobber length in the tail stock or. Mount my 250 long 14mm drill in the four jaw, mount my stock on the cross and do the entire length in one go. With this method I would turn a sleeve for the long drills and mount them in the steady about half way then remove it to drill the rest. I will in either case have to use a 7mm to start then the 14mm. I have tried going straight in with a 14mm but know dice. Max the machine is happy with is 10mm I chose 7mm to start because I find it you go to close to your finish size drill it tends to encourage wonder (not sure if that's just me). I hope this is understand.
Thank you,
Woody.
