I Hate Brass!
I Hate Brass!
Home Forums Materials I Hate Brass!
Viewing 21 posts - 1 through 21 (of 21 total)
  • #455827
    jimmy b
      @jimmyb
      I made my mate something out of brass last night.
      Nice looking job, really quite pleased with it!
      I have just spent twice as long cleaning up the mess! Everything within a few feet of the lathe was lightly coated in tiny bits of brass, the bedways totally clagged up with brass and slideway oil.
      At work, in a CNC machine, brass is great, but I do hate it at home…………..
      Jim
      Edited By jimmy b on 07/03/2020 07:33:32
      jimmy b
        @jimmyb
        #455828
        Hopper
          @hopper
          The old dodge is to make a chip guard by tearing one side off a cardboard fag packet and jam it over the tool bit shank. I imagine a bit of shim stock or clear plastic from a piece of packaging etc would work too.
          #455831
            What were you cutting with I find **GT tip don't give the shower of fine chips that a flat topped HSS tool does. Even hard brass can come off in curls if the feed is right.
            #455839
            Nigel McBurney 1
              @nigelmcburney1
              Spent my training on centre lathe turning brass for days on end,I like machining it,chips can be deflected by inserting a bent piece of shim under the front toolholder screw. On a capstan lathe all our brass turning was carried out with full flow soluble oil,this lubricated and cooled the tooling plus stopped the swarf flying.
              #455842
              Mick B1
                @mickb1
                I cut brass dry, then vacuum up the swarf. I find it easier than most other metals as normal machining brass cuts a disconinuous chip and doesn't 'birdsnest'.
                If I'm doing a deep cut, I'll hold the vacuum cleaner nozzle near the tool to draw the stuff off, until I get too close to the chuck jaws to do it safely.
                #456029
                jimmy b
                  @jimmyb
                  Thank you for the advice.
                  I was using ground inserts (GT), at the start, but had to machine a counterbore and got lazy!
                  After cleaning up everything and re-oiling another mate appeared with a "quick job", made from brass……………..
                  Jim
                  #456038
                    Funnily enough my favourite metal is Brass! Admittedly a bit messy, but cuts well, easy to get a good finish, fairly hard, and reasonably strong. Better in many ways than either Aluminium or Steel both of which have their own quirks! Brass, I think, is a good metal for beginners to try first. Unlikely to be very soft or very hard, or to be anti-social like that innocent looking work-hardening stainless steel.
                    But for real mess, cast-iron is surely the winner! Far worse than brass. Machines well, apart from when it comes with a glass hard skin, but cutting produces a fine black powder that goes absolutely everywhere, into slides, up your nose, and, floating in the air, all over the workshop. Last time I worked cast iron, I found black specs on the white goods in my kitchen, two closed doors away from the lathe. It's bad for precision machine surfaces too because it tends to stick to slides where it catches and holds grit to form an effective abrasive, multiplying wear. Takes a lot of cleaning too.
                    Vic
                      @vic
                      I don’t use brass very often but I had several parts to make from it recently and then recalled how nice it was to machine.
                      #457879
                      Nigel Graham 2
                        @nigelgraham2
                        Those brass "needles" can be a curse, and no mistake, finding their way around the house if you are not careful.
                        My worry with cast-iron is not so much the mess – unpleasant but something you tolerate for the finished result – but all that graphite (the black dust) near the motor. I am not sure I really want conductive dust floating about near the lathe motor's cooling intakes, just behind the headstock on a Myford. I use a sheet of insulation board as a shield but it doesn't keep all the muck away.
                        (My Harrison lathe's motor is in the open air too, but up on a frame above the headstock, some way from the chuck.)
                        #457932
                        Chris Gunn
                          @chrisgunn36534
                          Nigel G 2, if you are worried about swarf in the motor, as I would be, just imagine what a curly spiral could do, if it went through a cooling vent. Change them to Totally Enclosed Fan Cooled motors, TEFC, there are no cooling intakes. I suspect that such motors should/would have been fitted in the first place, but could have been replaced, when changing from 3ph to 1ph for example.
                          Chris Gunn
                          #457935
                          not done it yet
                            @notdoneityet
                            At least brass is not magnetic, so if it could be blown in it might be blown out again! Machines, so poorly designed that swarf can easily enter the motor, need modifying, IMO.
                            #457941
                            Hopper
                              @hopper
                              My old Drummond had an open-ended motor on it when it came into my care. Motor was chock full of 20 or 30 years of swarf. (It was the "new" motor Dad put on in later years!) Still seemed to work ok but I don't know how. It's now remounted safely below the work bench with a very long belt up to the countershaft.
                              #457955
                              Howard Lewis
                                @howardlewis46836
                                There is a fortune awaiting the man who produces a magnet that attracts brass and copper alloys. But it ain't going to happen.
                                The danger with brass is that if you get a particle in the eye, it has to be removed physically, rather than with a magnet like ferrous particles. So even if the fact that it sprays swarf everywhere is not insuperable, do wear some form of eye protection!
                                #458032
                                Robert Butler
                                  @robertbutler92161
                                  Speaking of magnets, many years ago one of the typists lost the diamond to her engagement ring. I suggested she visit the local jewellers and ask if she could borrow their diamond magnet – she was fuming on her return which added to the fun in those far off non PC days. Robert Butler.
                                  #458037
                                  old mart
                                    @oldmart
                                    You could try to cover up the bed with tissue paper, of vacuum up the stuff as it sprays off the tool. Only cast iron dust is worse, I recon.
                                    #458141
                                    Hollowpoint
                                      @hollowpoint
                                      Brass is messy but it is easily contained. Cast is also horrable but I hate those long swirls of aluminium most! Especially when the get cought up in the chuck. 😖
                                      I sometimes cover my machine with tin foil. You can squash and shape it to fit without interference. Then its just a simple matter of folding all the swarf into a ball to clear it away.
                                      #458456
                                      Bill Dawes
                                        @billdawes
                                        When I was an apprentice back in '57, during my time in the machine shop I worked back to back to an old fella who turned a lot of brass bar. When parting off he normally kept the stream of chips under control with a steel rule acting as a deflector, except when he decided to share it with me, showering me with the stuff and walking home at night every other step was a kangaroo hop from the bits stuck in my socks.
                                        Happy days! H&S very minimal then.
                                        Bill D
                                        #460618
                                        Erik Werner Hansen
                                          @erikwernerhansen82920
                                          I have made the finest curls with a sharp HSS bit in my Diamond Tool Holder.
                                          But I'm sure I'll now make some kind of guard next time anyway.
                                          Why not make it easier on myself?
                                          Cheers
                                          Erik
                                          #460852
                                          Jon
                                            @jon
                                            Time to worry is when yo want the job done, travels 4 foot to a wall, bounces back 3 foot and embeds in your arms.
                                            Horrible stuff.
                                            #460872
                                            Kiwi Bloke
                                              @kiwibloke62605
                                              Posted by Howard Lewis on 18/03/2020 12:57:22:
                                              Yes!
                                              It's probably been said here before (by me?), but it bears repetition. Copper and (many of?) its alloys in the eye is a disaster. Cu chemically destroys eyes quickly. Get those safety spectacles on! If you think there's any possibility that a bit has penetrated your eye, get to A&E without delay.
                                            Home Forums Materials Topics
