I fancy a new engine
Home Forums I/C Engines I fancy a new engine
  • #2494
    AJW
      @ajw
      AJW
        @ajw
        Having built a couple of steam engines, a Stuart no4 and a PM research mill engine which I found most satisfying to build and they both run a treat, I fancy an IC engine.
        Looking for casting availability I have found a few hit & miss types but I really want a 4 stroke horizontal type of about 1 1/5 inch bore and 2 inch stroke, or so with heavy flywheels to give a nice slow tickover!
        Anyone point me in the right direction?
        Alan
        #345942
        Paul Lousick
          @paullousick59116
          What about the Wallaby engine, recently discussed on MEW.
          Paul.
          AJW
            @ajw
            Thanks, nice compact job but I am yearning for a single!
            Alan
            #345990
              So if you don't want a horizontal hit and miss then you will need to be looking at a throttle governed engine.
              Centaur or Wyvern are the obvious two both by westbury, one available from reeves the other from Hemmingway
              #346016
              Perko7
                @perko7
                You could look at the power unit in the 1-1/2" scale Aveling DX road roller described by ETW in the ME starting January 1938. It is a horizontal water-cooled 4-stroke single approximately 1" bore by 1-1/4" stroke.
                #346018
                Roderick Jenkins
                  @roderickjenkins93242
                  The Aveling engine castings are available from Engineers Emporium though I can't see it on their website.
                  HTH,
                  Rod
                  #346055
                    Very few of their offerings are on their site, the do put the DX in some of their adverts but just ask them for the catalogue. Which reminds me they do the "the Senior" of Tom Senior fame and if you fancy a challenge then the "Pioneer" with it's Loyal Cycle is a bit different.
                    I was thinking about the Senior myself but having just won a flame ignition casting set on e-bay last night and put in an order with Graham of Alyn Foundry for a couple of engines will have to put that on hold.
                    #346111
                    AJW
                      @ajw
                      Thanks! The Wyvern and Centaur in particular are the sort of engine I was after. Found some running on YouTube and they can sound great I thought although I haven’t been able to find the bore/stroke of the Centaur? have any of you built one? and is it possible on an ML7 with a milling head attachment?
                      Alan
                      #346112
                        Centaur is 1" bore x 1.75" stroke.
                        Senior is 1.5" x 3"
                        Centaur and wyvern can all be done on a Myford with accesories, Rod has done the Wyvern
                        Few details of the Senior here
                        Edited By JasonB on 14/03/2018 20:42:27
                        #346114
                        Roderick Jenkins
                          ETW's description and drawings for Centaur are available (totally legally, it's one of the hidden documents on the ME site) here:
                          Rod
                          #346127
                          AJW
                            @ajw
                            Thanks for the link Rod, I see it’s 1 1/2 bore and 2 inch stroke! A nice size.
                            Alan
                            #346152
                              Posted by AJW on 14/03/2018 22:07:55:
                              Thanks for the link Rod, I see it's 1 1/2 bore and 2 inch stroke! A nice size.
                              Alan
                              I thought it sounded small when I took those dimensions posted earlier from Reeves catalogecrook
                              #346175
                              AJW
                                @ajw
                                Size does matter!
                                Alan
                              Home Forums I/C Engines Topics
