You have seen odd bit sof this engine in teh workshop progress thread over time and with teh Forest engine running well I thought I may be on a bit of a run. So armed with a new cylinder of propane thought I would give this one a go to see if it had gone back together OK after painting.
It took a while to find the sweet spot. First of all it had a tendency to fire too soon which I put down to too high compression. Now I may only have a green dragon machine that some say won't turn concentrically and only have a cheap brake cylinder hone not a smelly proper Sunnen machine yet with just one vitron ring fitted I was getting very good compression infact almost too much which resulted on it firing every 3 or 4 cycles and petering out usually ending in a backfire that sent it violently into reverse before stopping.
Then I had a
moment and remembered that when building the engine I had found that there was less compression when the primary exhaust was open as the piston does not cover it until part way towards the head so took out the plug and gave it a try. Certainly ran with a loud pop and threw out a few large flames at crotch height
. However it still did not fire on every stroke and seemed weak and would again slowly die but at least there was no backfire.
Finally found the sweet spot with the primary exhaust plug left slightly loose which acted a bit like a decompression valve and away it went. It's always nice when you can choose when to stop an engine rather than snip the video short just before it comes to a halt by itself and just show that its not what you have in the workshop that matters but what you do with it and subsequently comes out the door
Another big thank you to Graham Corry for making the patterns available again and for the help and encouragement along the way.
