Hydrogen-powered train makes UK maiden journey
Home Forums The Tea Room Hydrogen-powered train makes UK maiden journey
Viewing 25 posts - 1 through 25 (of 26 total)
  • #498569
    Ady1
      @ady1
      Ady1
        @ady1
        #498575
        Oldiron
          @oldiron
          Watched the video this morning. Progress at last. I hope it develops enough to be useful for longer journeys.
          regards
          #498595
          J Hancock
            @jhancock95746
            Not against the idea but it still relies on 'making electricity' by a rotating machine , with all that implies, in order to
            'recharge ' the tanks .
            ' That' ( nuclear power stations ), are falling like skittles at the moment ( Hitachi, EDF, China?/Sizewell/Bradwell ).
            #498605
            not done it yet
              @notdoneityet
              Posted by J Hancock on 30/09/2020 09:26:21:
              At the moment I expect it is actually running on fossil derived fuel. No moving parts for solar PV energy production, mind. Hydrogen production from electricity is only worthwhile when there is a surplus, over grid use, which cannot be utilised elsewhere. Can’t see it happening in the short term. Maybe in a few years?
              #498606
              Swarf, Mostly!
                @swarfmostly
                Here's an interesting read:
                Hydrogen
                Best regards,
                Swarf, Mostly!
                #498609
                  … it still relies on 'making electricity' by a rotating machine …
                  Not at all; solar panels. Solar isn't good at meeting fluctuating demand, but it's fine as a way of converting water into Hydrogen and Oxygen, faster on sunny days. Both gases are valuable.
                  As water and sunshine are both free, and the process isn't polluting, and burning Hydrogen doesn't cause global warming the economics are favourable.
                  The big problem with Hydrogen is it goes bang mixed in almost any proportion with air. Much more difficult to handle safely than other fuel gases. It can be done, but I don't see domestic central heating systems burning it!
                  john fletcher 1
                    @johnfletcher1
                    I'm amazed at people who think electric cars is the answer to our pollution problems. Where do they think the electricity comes from and how is it produced. Also, the capacity of under ground cables are just not big enough to power all the car battery chargers which will be required. When our house, which was typical at the time it was built, it had a light in each room and one socket in the hall. Now most home up the road have a washing machine, dryers, fridge, freezer, immersion heater the list goes all on a 1920 cable and there is just one joint per pair of semi's. Just imagine how much energy is required to make a wind turbine and how long will they last, also consider the amount of energy to make PV panels and how long will they last. Then we have the biomass power station, importing the pellets from the US, apparently it just as polluting as the coal power station ever was, and what about the ship bring the stuff from US. As for hydrogen what a dangerous substance to have a train. John
                    #498612
                    not done it yet
                      @notdoneityet
                      Yes, but… Almost all hydrogen is currently produced from methane – a fossil fuel – which does cause. CO2 pollution. The only advantages of using that source of hydrogen is to reduce (to zero) the pollution at the point of use, and as a ‘bridge’ between electrified sections.
                      Currently, producing hydrogen by electrolysis is barely a 65% efficient process, let alone the inefficiency of the fuel cells (less than 70% efficiency?) Using electricity from source to drive the motors, or charge the battery (still needed in this scenario) makes much more sense – at the present time – until there are relatively huge surpluses of ‘green’ electricity available.
                      Even Scotland, which can generate more than it needs for its grid, overall, still does not produce all of its requirement from wind/solar generation. No sunshine at night and the wind does not blow evenly all the time.
                      #498613
                      Hopper
                        @hopper
                        Posted by Swarf, Mostly! on 30/09/2020 10:02:17:
                        Hydrogen
                        Best regards,
                        Swarf, Mostly!
                        Written by climate change denialist David Archibald who works for the US Heartland Institute which is funded by the oil industry.
                        So be sure to read some other sources as well to get the full story.
                        Edited By Hopper on 30/09/2020 10:54:59
                        #498617
                          Posted by john fletcher 1 on 30/09/2020 10:29:17:
                          … Where do they think the electricity comes from and how is it produced. …
                          You can see where it comes from here:
                          At 10:25 this morning the main UK producers were meeting a 35GW demand with:
                          • Gas – 45%
                          • Renewables – 34%
                          • Nuclear – 17%
                          • Coal – 1%
                          • Others, including Hydro, about 2%
                          And 3% of UK production is being exported to France.
                          Of the Renewables, Wind is producing 27%, Solar 4% (despite 100% cloud cover here), and Biomass 3%.
                          Not long ago when I first found this forum many posters claimed coal generation couldn't be replaced. Impossible, and yet here we are!
                          Edited By SillyOldDuffer on 30/09/2020 11:49:03
                          #498622
                          J Hancock
                            @jhancock95746
                            Just a small point which few of us know , about the use of hydrogen.
                            It has a heat transfer 2000x that of air and pure hydrogen is used to cool the big 660MW alternators in
                            our power stations.
                            No failures yet, that I know of.
                            #498635
                            Jeff Dayman
                              @jeffdayman43397
                              For hydrogen powered cars of any sort there are a total of 13 refueling stations in the UK at present (from wikipedia) many in or near London, not surprising, really. Certainly not a station at every crossroads.
                              Luckily for those in Northern Scotland there is a station on Orkney, so just a short ferry ride and several hours driving to fill up! Good for the environment! smiley
                              In industry I have been involved with several projects to do with components for hydrogen powered fuel cells. These are very large cells being planned for semi-trailer full size highway trucks, highway buses, and more recently, electric trains. A big Germany-based electrical products firm is doing the trains.
                              #498642
                                Posted by SillyOldDuffer on 30/09/2020 10:24:34:
                                Naive question : Is the water required to be ultra-clean and pure ?
                                … and if not, how (and at what cost) will the tanks be cleaned ?
                                J Hancock
                                  @jhancock95746
                                  The question is about best use of the electricity produced first, a bit like growing wheat, etc, for bio-fuel, when eating it would be a better use ?
                                  As for getting rid of gas !!!!! by 2050 AND being all electric heating ,etc, no chance at present rate of progress.!
                                  #498650
                                  pgk pgk
                                    @pgkpgk17461
                                    UK electricity usage has been falling since 2004 by some 50 terawatt-hours so capacity for more EV's isn't the primary issue. While hydrogen has lots of losses in creation and use I'd expect future improvements there. One of the big issues with EV's is the energy wastage carrying the weight of those batteries about as well as time to recharge if using small battery packs. Big packs can get the first part reloaded quickly.. we do have 350KW charging stations being built now – just need some cars that can take that charge rate.
                                    Reality remains that practical EV's are beyond most folks budget unless only using them for moderate daily commutes and local journeys (it is the majority of use). The other issue is access to charge points when living with on-street parking altough there are innovations there too. The biggest drawback is the price of leccy from these new charge points compared to home charging and how many charge points are forever out of commission – after an enthusiastic grant funded construction many don't get maintained well enough. Ecotricity is probably the main culprit in that regard.
                                    The better benefit from electrolysis to H2 is avoiding waste when the wind blows and they turn off the extra turbines and still pay the companies for what could have been generated? Or is that just rumour?
                                    pgk
                                    #498663
                                    Oven Man
                                      @ovenman
                                      Why do we always have to reinvent the wheel in this country. Hydrogen powered trains have been running in Germany for some little time now, so somebody has already cracked the problem of installing all the kit in a train properly.
                                      #498671
                                        Just an observation, the main benefit for fuel cells (aside from greater flexibility in torque curves, mechanical simplicity, reliability etc.) over using it in an IC engine is that you don't get all the nitrogen oxides.
                                        But yes, it is less efficient than batteries by quite a margin and requires more infrastructure, but as some have observed above if you 'refine' it using surplus power that becomes a non-issue.
                                        Ian Johnson 1
                                          @ianjohnson1
                                          This is an interesting topic! The big chemical site where I used to work is investing heavily into hydrogen manufacturing. The added benefit is oxygen as by-product.
                                          It is has also been a by-product of chlorine manufacture on site for over a hundred years, and has been used in the site power stations as a supplemental fuel for decades. It's a very useful gas!
                                          And the go ahead has just been given for live trials of mixed hydrogen and natural gas for domestic use in the North of England.
                                          IanJ
                                          #498705
                                          duncan webster 1
                                            @duncanwebster1
                                            This describes making hydrogen from methane without producing CO2, it produces soot instead. I've no idea of how much energy is involved **LINK**
                                            I believe that Germany already uses excess green power to produce hydrogen, and then pumps it into the gas main. Not as daft as it sounds because using gas for space heating is very efficient, and the gas main provides huge storage capacity. There is an upper limit to %H2, so I've read somewhere that they are working on converting the hydrogen to methane, which does seem counter-intuitive
                                            #498737
                                            Tim Stevens
                                              @timstevens64731
                                              Remember that when petrol was introduced for motoring (etc) there were scares about it being highly explosive mixed with almost any ratio of air. The railways banned the transport of petrol in tins – which was the only way it could be supplied to motorists pre-1910. But we found ways round it.
                                              Electrolysis of water does not require pure water – in fact it is much less effective in pure water which is nearly an insulator.
                                              When hydrogen is used instead of 'natural gas' someone needs to consider the relevance of the term 'natural'. Hydrogen is the nuclear fuel that keeps us all alive – not much more natural than that, is there?
                                              Cheers, Tim
                                              #498740
                                              old mart
                                                @oldmart
                                                Ihate it whenever I see a vehicle proudly displaying "zero emissions", some people actually believe it.
                                                #498752
                                                Keith Matheson
                                                  @keithmatheson47708
                                                  Containable nuclear fusion reactors producing more electricity than we need, coupled with electrolysis plants splitting water (abundant on earth) into Hydrogen and Oxygen. What’s not to like! Well maybe in 30 years time! Who knows what the planet will look like by then though! Returning to lurking mode.
                                                  #498782
                                                  S.D.L.
                                                    @s-d-l
                                                    Peak generation and distribution Capacity is near 50GW, averahe use is 32GW and mininum draw <20GW so as long as cars are charged off peah there is a lot of capacity,.
                                                    The use of smart meters will allow for more management of who charges when, and faster charging stations are appearing at petrol stations now,
                                                    I filled in online survey with one of the fuel majors where I pay at the pump and they clearly see themselves as an Energy company, watch to see how much some of them shift to renewables.
                                                    Steve
                                                    #498974
                                                    mark costello 1
                                                      @markcostello1
                                                      Same crooks, different show.
