Posted by not done it yet on 02/07/2023 21:36:01:
It’s a one way ram, so unlikely to be the actual ram if it is not leaking oil. That leaves leak-back through the pumping mechanism. Fresh O rings should be a few pence as a fix –
Yes, that's what I assumed, when repairing my car trolley jack. It had developed a leak past the pump piston, so I took it to bits, and the pump O ring was as hard as plastic, flattened, and it broke into three pieces, when I extracted it.
So I measured the ID, OD and cross sectional diameter. Unfortunately none in my O ring kit were close enough to fit correctly, so I contacted a hydraulic supplier to get a new one. One comedian wanted £10 + postage for a single ~13mm O ring !!!
I just ignored his email and got the nearest larger size O ring with the correct ID from my kit and filed down the OD and profile by spinning it mounted around a bolt in an electric drill, and holding a file against it. Fitted and worked perfectly.
(And, no; I never rely on the trolley jack to support the car; I always use axle stands before going underneath.)
