Hydraulic ram for IC engine cylinder
Home Forums Materials Hydraulic ram for IC engine cylinder
  • #756770
    Mick Bailey
      @mickbailey28509
      I have some 1 5/8″ diameter steel that’s cut from scrap hydraulic rams. I’ve been using pieces for many years instead of M/S and it machines nicely. Would this be suitable for an IC engine cylinder? I need a finished OD of 1.5″ and this would do just nicely.
      Brian Wood
        @brianwood45127
        Mick,
        I don’t see why not, it is quality steel, resistant to bending, whether or not that is important to your planned use I don’t know.
        Others may have different views.
        Regards  Brian
        #756777
          It is something I have thought of using and have seen others use it but not found a source for short lenghts. With it’s already honed bore it should work well.
          It would be idea for a single Viton ring which are less hastle than making iron rings. Just 5% of cross section compression of the ring.
          #756815
          bernard towers
            @bernardtowers37738
            I think hes talking about the rams not the cyls
            #756820
            noel shelley
              @noelshelley55608
              It will be good steel and hard chromed, though of little matter if only being used as stock – I take it you are referring to piston rod ? Good Luck Noel.
              #756831
              Nick Wheeler
                @nickwheeler
                The hard chrome can be a bit challenging to cut through if using a small lathe. You can salvage good quantities of similar material from used Macpherson struts(Vauxhall Omegas provide about 500mm of 22mm diameter rod) and smaller diameters from the ubiquitous gas springs.
                #756835
                bernard towers
                  @bernardtowers37738
                  I find that when machining hyd ram rods its easier to feed along the work with a deepish cut this peels the chrome off easily
                  #756879
                  Mick Bailey
                    @mickbailey28509
                    The chrome comes right off without any problem. I wondered about the wear characteristics when machined as a cylinder for a slow revving engine. I’m thinking of using a cast iron piston.
                    The honed hydraulic tube Jasonb refers to only seems to come in 6m lengths. It would be a nice source of material to get hold of different sized offcuts as the wall thickness can be quite hefty.
                    #756891
                    Diogenes
                      @diogenes
                      Piston of CI probably best choice of material and should be fine, lapped to a good fit you might get away without using rings for a display engine. I’d expect wear to be virtually negligible once it’s all settled down.
                    Home Forums Materials Topics
