The article mentions the Bond, actually a brand-name used by Sharps Commercials.
I had two of the Bond ‘Minicars’, resembling a rather angular Reliant, and perhaps slightly longer.
These had Villiers motorcycle 2-stroke engines, 200 or 250cc I think by year of manufacture, chain-driving the single front wheel by mounting the engine and gearbox unit on a swinging-arm controlled by a shock-absorber, projecting forwards from a vertical, tubular column that carried the steering worm-quadrant at the top, and the gear-change linkage down through it.
The gear-lever on the steering-“column” (horizontal) was linked through to the original gear pedal on the gearbox.
6V electrics, with a massive rotor on the end of the crankshaft, for the Siba ‘Dynastart’ whose starter-motor / dynamo function was set through the ignition-switch wiring. This allowed reversing by starting the engine backwards, via a gated second switch position, but I forget if this used two contact-breakers or a single one with TDC timing.
The steering position was a bit odd, with the steering-wheel in a vertical plane but its shaft at an angle to the bodywork to reach the quadrant.
The two variants were the 4-seater saloon, with rear luggage space reached by a side-opening door; and van, with just two front seats. Proper (for the day) locks on the two front-only doors, a pair of square-hole type latches on the rear. You could open them without damage using just a wide screwdriver! I blanked them with screws and nuts.
Pressed-steel chassis members, aluminium floor and side-panels to waist height, fibreglass above that.
Sharps were also the builders of the ‘Bond Bug’ in the early-1970s.
Not mine, but a preserved example of a different form of the ‘Minicar’: mine was the full-height estate pattern as I think the partially-eclipsed green one is:
