It has to be said that grinding HSS is not that easy – to get consistently sharp – and consistent is probably the operative word – without some sort of grinding jig or cutter grinder.
From that point of view, the Eccentric tools holder looks very good, because even with a proper tool and cutter grinder, it does take a few minutes to set up before grinding. That thing looks as if it will work of a plain offhand grinding wheel rest. – and you get easy set up screwcutting tools out of it as well.
I think, for the model engineer, the advantages of carbide are somewhat misrepresented. Everyone goes on about speed of cutting etc. That’s not it for me – its the fact that you can have, quickly, conveniently and easily, sharp tools with no hassle (at a price!), which will consistently produce a good to excellent finish. Are they sharp – yes – very. But the radiused tip means that often they are reluctant to do a shaving cut, so hitting a diameter to say +/-.0002″ is a matter of good technique.
The only disadvantage perhaps, is the rake. With HSS you can grind in quite a steep rake angle which generates an “inwards” pull. That greatly reduces the load on the feed mechanism (Don’t go overboard!). You don’t get that with tips. That is quite a help with the smaller ME type of lathe
So you pays your money and takes your choice. I use tips almost entirely, but I do keep a selection of Quorn sharpened HSS for particular tasks. Also with an adaptor for ER25 collets, the Quorn is just brilliant for sharpening drills, slots drills, and spiral cutters like endmills – paid for itself hands down.
Oh and the one tipped tool that is just the must have – can’t be without, won’t jam – is a proper parting tool. I have a Glanze sliding blade type with a 2mm wide tip. And one from Greenwood which uses the Sandvik 2.5mm tip. The Kit Q cut from Greenwood is the more expensive, and cuts much more freely and to a better finish, even though it is broader. Probably the tip geometry. The Greenwood is, for my money not only superior, but can also be fitted with a greater variety of tips.
Edited By meyrick griffith-jones on 09/08/2009 09:45:01
Edited By meyrick griffith-jones on 09/08/2009 09:46:26
Edited By meyrick griffith-jones on 09/08/2009 09:55:08
