Hi
I have just bought a used steam engine. The engine came with handpump and an injector. The handpump works fine, but I am not sure whether the injector works or not.
I have fired the engine twice. First time nothing happend with the injector. I removed the injector and descaled the injector, and found out that a small ball inside was previously stocked. The secondtime I fired the engine I could see water was in the tube going into the boiler, there was hot water on tube, the conenction is a litle bit leakt, but the waterlevel glass did show clear indication of the boiler being filled with water.
So can any body tell me what todo, is there a relationship between how much to open for the steam to the injector, perhaps something around working pressure, I operated the injector around 30 psi, sound indication, or should an injector be replaced at sometime, my engine is used
regards
Max
