Howell Twin Four Stroke – completed item
Home Forums Work In Progress and completed items Howell Twin Four Stroke – completed item
Viewing 21 posts - 1 through 21 (of 21 total)
  • #347831
    CorRad
      @corrad
      I have completed building the Howell Twin 4 stroke. The link below takes you to a video of the completed engine:
      Edited By Neil Wyatt on 28/03/2018 10:42:25
      CorRad
        @corrad
        A video of my completed Howell Twin 4 stroke model engine
        #347850
          Presumably because YouTube 'knows' that I am using an iPad …
          using your URL takes me to
          https://m.youtube.com/watch?feature=youtu.be&v=F44qslr_AEA
          … and that displays a black window with white text, stating:
          This video is unavailable
          sad perhaps I am not worthy
          Edited By Michael Gilligan on 28/03/2018 08:37:54
          #347851
          Perko7
            @perko7
            Found it at this address:
            #347856
              Posted by Perko7 on 28/03/2018 08:43:15:
              Thanks yes
              That one works
              https://www.youtube.com/watch?v=F44qsIr_AEA
              Edited By Michael Gilligan on 28/03/2018 09:37:34
              #347857
              Joseph Noci 1
                @josephnoci1
                Hello Corad.
                Brilliant Engine! Runs great and looks fantastic. Very well done, and certainly done in a short time!
                While looking at the video, I saw this one…Amazing how inventive folk are!
                Joe
                https://www.youtube.com/watch?v=eKY-UNYdDHE
                Edited By Joseph Noci 1 on 28/03/2018 09:41:54
                #347863
                CorRad
                  @corrad
                  Apology for the problem with the link. I typed the address in stead of copying the link as a hyperlink. The link below works. Thank you Joe I enjoyed the building. The engine made from car scrap is certainly very innovative.
                  https://youtu.be/F44qsIr_AEA
                  #347866
                    Embedded it.
                    Nice work Conrad!
                    not done it yet
                      @notdoneityet
                      Is it fuelled by metanol in order to run cooler? I note there is no forced air cooling.
                      I think the advantages of a shorter, stiffer crank is better in the V formation, rather than a 360 degree crank in an in-line configuration.
                      Nice work and runs well.
                      #347875
                      Trevor Crossman 1
                        @trevorcrossman1
                        Congratulations CorRad, your result of six months labour looks and sounds very good indeed.
                        Trevor.
                        #347877
                        CorRad
                          @corrad
                          Methanol is used primarily because the emissions are much cleaner. There are two 50mm diameter computer style cooling fans on the front of the engine aimed at the heads. The drawings actually calls for a sheath over these fans that result in much more effective cooling. However, the look of the engine without these sheaths appeals more to me. The longest time that I have run the engine continuously was for 10 minutes. The heads certainly did get relatively hot but not to the extend that it was considered a problem. Should I want to run this engine for long periods, I will certainly have to add these sheaths. I agree with your remark regarding the short crank.
                          #347908
                          daveb
                            @daveb17630
                            CorRad, very nice indeed!
                            Daveb
                            #347942
                            John Rudd
                              @johnrudd16576
                              Does the starter motor remain engaged while the engine runs?
                              #347949
                              CorRad
                                @corrad
                                Good question. When I had to make decisions about the starter motor, this did worry me. Yes, the starter motor remain engaged after the motor has started. The life time of the starter motor bushes is therefore in question. However, this allows the starter motor to be used as a dynamo to charge the battery.
                                #347952
                                John Rudd
                                  @johnrudd16576
                                  Posted by CorRad on 28/03/2018 21:05:58:
                                  Just be careful that the engine does not over rev the starter motor….there is a risk of bursting the windings on the armature….I know…I have done it on a car! The starter got jammed with the flywheel gear…
                                  #347955
                                  CorRad
                                    @corrad
                                    Thanks for that information.
                                    #347988
                                    Ian S C
                                      @iansc
                                      A car starter motor is usually between 15:1 and 20:1, where as the starter on CorRad's motor is nearer to 4:1.
                                      Ian S C
                                      #347996
                                      CorRad
                                        @corrad
                                        Correct Ian S C. Initially, this caused a problem in that the starter motor does not have enough torque to turn the engine when it is one of its compression strokes. In order to start the engine using the mopet starter motor, I have to manually turn the flywheel in the opposite direction that it normally runs, until a compression stroke is reached. When the starter motor is energised it can then build some momentum before a compression stroke is reached. This works fine and the engine is easily started as can be seen on the video.
                                        #347999
                                        thaiguzzi
                                          @thaiguzzi
                                          Impressive, pretty, like it.
                                          #348097
                                          Ian S C
                                            @iansc
                                            Starter motors are usually series wound, so not ideal as a battery charger, but a modern starter may have permanent magnet fields. A generator for battery charging with wound fields needs to be shunt wound.
                                            Ian S C
                                            #348730
                                            CorRad
                                              @corrad
                                              I have uploaded two videos of my other completed engines. The links are below: https://youtu.be/_PH-iE7YmdY​ https://youtu.be/bZX-ajNffrY
                                              Edited By JasonB on 04/04/2018 07:20:50
                                              Edited By JasonB on 04/04/2018 07:43:11
