Just a follow up. Last night I had a go trying to drill out the broken tap with one of the two solid carbide end mills I purchased off Amazon. Well the first end mill just destroyed it’s self turning into dust. The second did the job, but only just. Like most things I have purchased one line over the years the quality is hit and miss. O how I long for the good old days when I could visit real tool shops and engineering suppliers, talk to real knowledgeable people face to face and purchase good quality tools that did not break the bank.
I really wouldn’t condemn the end mills in this case. Trying to use a solid carbide end mill to drill out a 6BA tap with a (handheld?) Dremel rotary tool is practically guaranteed to result in breakage of the end mill.
Everything is against you: the small (and therefore very flexible) end mill, the difficulty of centering it in the hole and stopping it from wandering, lack of rigidity in the set-up, questionable and fluctuating perpendicularity, the jaggedness and hardness of the surface being milled…
