How to remove heat marks from mild steel
Home Forums Beginners questions How to remove heat marks from mild steel
  • #114339
    Grandad2448
      @grandad2448
      Hi
      i am sure this must have been covered somewhere but i searched and found no answer? I have a mild steel component with a 'rainbow' stain caused by heat, how can i remove this mark?
      thanks
      Richard
      Grandad2448
        @grandad2448
        #114427
        Brian Wood
          @brianwood45127
          Hello Grandad,
          Try using some used scotchbrite pad that has had the 'keeness' taken off it, red or green pad will do and match the very light abrasion it gives with other markings on the job [such as machining marks etc] to hide its use.
          The removal of metal is truly miniscule, the heat marking is only molecules thick anyway and it will disappear as if by magic.
          Brian [another grandad]
          #114440
          Ian S C
            @iansc
            Richard, leave it soaking for a few hours in a solution of citric acid, say a spoon full of powder in a bowl of water, you might find the citric acid in the kitchen, if not the home brew shop is the best place, or the super market would be next, or you can stick it in a bowl with some Coca-Cola. When finished, wash in hot water with a scrubbing brush. Ian S C
            Edited By Ian S C on 14/03/2013 11:29:10
            #114442
            chris stephens
              @chrisstephens63393
              Garryflex rubberised abrasive blocks (in various grades) work very well at cleaning or texture-izing metals. I have been using them for years to fool people into thinking I can get a good finish.wink
              chriStephens
              #114444
              Robbo
                @robbo
                When the chromed exhaust pipes of our motorcycles got "Blued", we cleaned them with Solvol Autosol polish. This was of course in "the olden days", but Solvol is still available.
                Phil
                #114463
                M0BND
                  @m0bnd
                  I use phosphoric acid at work to get rid of oxidised blueing from titanium welding (I know it's not good and we do weld this stuff in a bath of argon but still get oxidation so not perfect!!!). It works wonders and would assume this will be ok for steels (ok on 316 st. st. too) – not sure about the carbon content and what it may do to it???
                  Andy.
                  #114470
                  Russell Eberhardt
                    @russelleberhardt48058
                    Posted by M0BND on 14/03/2013 21:33:28:
                    ISTR that that's the principal ingredient of Jenolite rust remover so should work OK on steel. You can buy phosphoris acid as teak cleaner in garden centres or boat chandlers.
                    Russell.
                    #114481
                    Ian S C
                      @iansc
                      You might find stainless steel cleaner powder in the cleaning gear in the house, used for stainless tubs, shower trays etc. Brass wire brush, either hand, or wheel. Ian S C
                      #114499
                      Mark P.
                        @markp
                        Metal polish such as solvol or brasso is as good as anything>
                        Mark P.
