How to remove a SMD resistor
Home Forums Electronics in the Workshop How to remove a SMD resistor
  • #587091
    modeng2000
      @modeng2000
      I would like to be able to remove a SMD chip resistor. Unfortunately it has been fixed with adhesive and soldered. I assume the adhesive won't soften with heat so what is the best way to approach this?
      modeng2000
        @modeng2000
        #587093
        Martin Connelly
          @martinconnelly55370
          The controls department where I used to work used a hot air tool specifically designed for this type of thing. Looks more like a soldering iron than a hairdryer.
          Martin C
          #587095
          Joseph Noci 1
            @josephnoci1
            Heat does work even if the adhesive is epoxy, etc. Use 20-40watt iron with a tip that can cover both ends of the SMD, put a blob of solder on the tip and apply to the smd – keep it in contact with both ends for 10-15sec. Use a small jewellers type screwdriver to gently prod at the smd every few seconds – it will move away..
            This will not work well if the PCB is phenolic/resin impregnated paper, etc – works fine on fibreglass pcb's – FR4, etc.
            Hot air may work, but will take longer and will heat the surrounding bits more than necessary.
            #587113
            modeng2000
              @modeng2000
              Thanks both for your helpful replies. The pcb is fibreglass so I'll give it a try.
              Anonymous
                How big is the resistor and what sort is it? For standard thick film chip resistors I use two 80W irons, one on each end. Even with glue once the solder is molten the resistor can be removed by pushing gently with the irons.
                #587117
                Grizzly bear
                  @grizzlybear
                  #587132
                  noel shelley
                    @noelshelley55608
                    I would use hot air, especially to fit a new one. Use foil to protect other components around the site.Noel.
                    Edited By noel shelley on 24/02/2022 21:27:36
                    #587178
                    modeng2000
                      @modeng2000
                      The resistor is approx 3mm long, value 110k
                      I'm sure it will let go with sufficient heat on both tags.
                      Anonymous
                        Posted by modeng2000 on 25/02/2022 10:52:58:
                        …resistor is approx 3mm long…
                        Probably 1206, ie, 120 thou by 60 thou, or 3216 in metric. Huge, should be no problem removing it.
                        #587198
                        Joseph Noci 1
                          @josephnoci1
                          Is the resistor broken/open cct? Do you need to fit a different value? If you need a lower value, put a suitable value in parallel – easier than removing the present one. If you need a larger value….
                          Joe
                          #587256
                          modeng2000
                            @modeng2000
                            Thanks Andrew.
                            Joe, I believe it is o/c and will consider paralleling with a conventional resistor for test purposes if this is the case.
                            Not sure if there is room to leave a wire-ended resistor in place when reassembled.
