How to Neutralize Bakers Fluid Flux.
Home Forums General Questions How to Neutralize Bakers Fluid Flux.
  • #509818
    peter brown 5
      @peterbrown5
      Hi All
      I am building a 5" Simplex and now soldering together the Lazer Model Engineers Kit using 1/4 " brass angle for extra support. I have strongly been advised to neutralize the Bakers Fluid flux, With what product and how best to proceed is my question? Any thoughts please.
      peter brown 5
        @peterbrown5
        #509819
        old mart
          @oldmart
          Rinse in hot water, repeat and the flux should be washed away.
          #509866
          Nigel Graham 2
            @nigelgraham2
            Would it be better to add washing soda (an alkali) to the first wash, to neutralise the acid?
            #509872
            Bill Pudney
              @billpudney37759
              Amongst many other things I build fuel tanks for model aeroplanes. These are tinplate fabrications soft soldered together using 50/50 plumbers solder and Bakers Fluid. The tanks must be pressure tested to ensure there are no leaks, then they are flushed out two or three times with a strong solution of hot water and bi carb soda. Then they are pressure rinsed with clean hot water, then dried as far as possible, obviously drying internally is a bit difficult. At this point the tanks are very clean and susceptible to rust, so the get a light spray with oil, inside and out.
              Job done………..finally
              cheers
              Bill
              #509978
              Dave Halford
                @davehalford22513
                The use of Bakers is not compulsory, I have use Laco, alledged not acid that will still cause fume rusting on nearby steel.
                Best bet is rosin cored solder. Tin both sides first, wipe off any excess solder with a rag then join together.
                #510259
                peter brown 5
                  @peterbrown5
                  Thank-You to all those who replied to my query, the answers were a great help!!
                  Thanks Peter.
